Question about 2wire (1000-400108-001) Router
I have a 2 wire router that i have had for years .Im thinking that it has gone bad or the power supply is one . I have no light on the router . can you give me any ideas on hoe to check and replacement ? dont know much about this stuff . Thanks
  • 38 Answers
Try to reset it for 30 secs, there could be a reset button. If it's not working , then I recommend that you buy a router. See tips on how to buy a router in http:wirelessmadeeasy.blogspot.com
Posted on Nov 08, 2010
Wireless router will not power up?
Capacitors in the power supply have gone bad. Might be time for a new router.
Mar 06, 2016 | Belkin Connect N150 Wireless N Router
Picture on my Toshiba 37RV753B has gone off and the standby light keeps flashing yellow. It was working ok a few hours ago, but I switched it off to go out and now it won't work. It's only just over a
Hello!
If you have used your TV 24/7 for the past year, the issue might be in the power supply. If there are "bloated" capacitors, set will not start up. If you haven't unplug it for a year, it might be staying alive. Once you unplugged the set, those capacitors won't let your set back to normal. That's a big project and requires technical background. If you think you can handle that, open your TV set and inspect TV's power supply board. It will be located near power cord plug or wire. Also, it might be covered by tin shield, which must be removed for further observation. If you see any "bloated" electrolytic capacitors, replace them with same value and voltage. But it might be main board's issue, as well. what is your place's ambient temperature? If it's lower, than 75F, try to warm up the back of the set, before even trying to poke it open. Use hair dryer. First, point it on main board's in/out connectors. Do not overheat! Few minutes might be enough. Then, try to plug the set in and observe the behavior. Any change? turns on? Main board is bad. Same with power supply. If heating up main board area does nothing, try power supply area. If it makes a difference, start looking for bad capacitors.
Good luck,
Let me know results.
Thanks,
Alex.
Dec 10, 2011 | Toshiba Televison & Video
We have been using the Netgear router WPN824 for about 3 years and all of a sudden it stopped working. No flashing strobe lights - nothing. any suggestions?
Will it even power on at all ? If there are no lights at all make sure its plugged in securely. Maybe even try a different power outlet to see if the one you are using has not gone bad. If that still doesn't help then there is a chance that your router has failed. Being 3 years old it is possible. A failure can be from a power surge, storm, manufacture defect etc. In which case you will have to replace it. Sorry for the bad news.
Thank you for choosing Fixya,
Daniel
Jun 26, 2011 | NetGear RangeMax WPN824 Router
My 2-wire 2701HG modem has a solid red power light and is not functioning. ATT says it is bad and out of warranty "sorry". Any other reasons for this condition?
RED power light indicates that the modem has gone bad.
Try with a different power cable and power adapter
Try with a different power source
Try to hard reset the router
NOTE: Have all details provided by your ISP before trying this step
If all the above mentioned steps doesn't work please replace it
Jan 27, 2010 | 2wire 2700HG-B Router (2700HGB)
I have Linksys - WRT54GS Wireless G Broadband Router working fine for the last 3 years and since one hour stopped working. I cannot see the light blinking on on wireless icon on the router. Any suggestions...
I've gone through two of those routers in a similar amount of time, it has most likely bit the dust. You can try connecting to it via wired and typing in the address (the default is 192.168.1.1) into Internet Explorer. There you will find the web configuration site for the router. Once you've logged in (the default access password is admin with no user name), go to the wireless tab and ensure that the wireless is not disabled (it will say, G-only, Mixed Mode, or disabled). If it is disabled, change it to the mode you need and apply the settings before you log off.
Jan 26, 2010 | Linksys Wireless-G Broadband Router
Netgear WNR834Bv2 failed - powerlight is off, but all other lights are on solidly incl the router and wireless lights (the latter solid, not blinking) and all four ethernet port lights, despite nothing...
If you haven't tried using the reset button, should be an explanation how to use it on the router in the manual, try that.
Also, try a replacement power supply to the router, if you can get hold of one. As this maybe faulty.
However, likely faulty router, maybe due to power surge, due to lightning/bad weather.
Jan 24, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I think the power supply is bad. the light on the front of tower is yellow and makes no sound when the computer is turned on. all three fans run.
No i don't think the power supply gone bad, as your decription says light on the front side is yellow and all the fans are running. This may due to RAM has been not been inserted properly or other hardware problems. Check all the connections of the hardware will resolve your problem.
Revert back for more assistance.
Dec 26, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Dell Inspiron flashing amber power light, not charging
I would think the batteries need replacing. That happened to my Dell Latitude CPI. The batteries won't charge past about 3%, so I got new ones and that did the trick. If this is under a year old I would contact Dell about it, if it is under a year old they should replace the batteries.
Hope this helps.
Feb 23, 2009 | Dell Dimension 8400 power supply ** FREE...
Belikin N series router, the ''wired'' icon is flashing orange?
It turns out that im not as stupid as i first thought????
I plugged the ethernet lead back into the router and my laptop and the orange "wired" flashing light that has been bugging me has now gone out.
I thought that maybe it was flashing for me to update the firmware but it must have just been a hiccup??
All is well now though. If it happens to anybody else then please try the basics that i tried first.
Jan 15, 2009 | Belkin N1 Wireless-N Wireless Router
2wire (1000-400108-001) Router Logo
22 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
