Question about HP Deskjet 3845 InkJet Printer
At bottom of page printer stops advancing and clunks until I pull the page out.
  • HP Master
  • 7,733 Answers
Clunk when pulling off from stop
check for worn loose "u" joints . check for loose drive shaft pinion. Check for worn suspension rubbers on rear end allowing the arms to move up and down
Apr 05, 2014 | 2006 Mitsubishi Outlander
Where to locate the Nissan Primera 2002 fuse box
Arghh just posted a long answer and it’s not accepted it after logging into fb, so short answer under steering wheel on your rhs if in the uk bottom row far end (last 10amp fuse) or under hood next to battery in long skinny fuse box with positions marked on top again your rhs red 50amp fuse or bottom peach 30 amp fuse on same side, pulling one under steering wheel will suffice and stop clunking until repaired disabling abs. A repair is preferable to ensure it all stays tip top.
Jun 27, 2013 | Cars & Trucks
Printer prints PDF but pulls page back in a few inches
Try this: Go to print a pdf file by clicking file/print. When the print properties box appears, click on the Advanced button on the bottom. Check the Print as Image box and click OK, then print your pdf file. If it still does not work, update, or delete and reinstall your print driver.
Aug 11, 2012 | Kodak ESP C315 Wireless All-in-One Printer
Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
Oct 20, 2009 | HP LaserJet P3005n Printer
Print test
Step Press Displayed Result Notes
1. Install the ribbon, load paper, and power on the printer.
2. NOT READY Printer must be in NOT
READY mode to access
the tests.
3. OPERATOR MENU
UNLOCKED
Unlocking ENTER key
allows you to test the
printer.
4. OPERATOR MENU
PRINTER CONTROL
First of series of
configuration menus.
5. OPERATOR MENU
OPERATOR PRINT TESTS
Advances to the Operator
Printer Tests menu.
6. OPERATOR PRINT TESTS
PRINTER DEMONSTRATION*
Advances to first option in
Operator Printer Tests
menu.
7. OPERATOR PRINT TESTS
[TEST NAME]
Cycles through list of
tests. Stop when your test
displays.
8. OPERATOR PRINT TESTS
[TEST NAME]
The test you selected
starts printing.
9. NOT READY The printer test stops
printing.
Stop
Scroll­ + Scroll¯
Menu
Scroll­ UNTIL
Enter
Scroll­ UNTIL
Enter
Stop
Let me know if you need any other help with this. I carry all parts and refurbished units and offer free techincal support as long as the parts ordered thru us.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
rcardenas@mrp.to
Jun 24, 2009 | IBM 6400-I2S Matrix Printer
Prints 2/3 of the way, stops, continues, bottom is faded
It sounds like you need to replace Toner Cartriage
May 19, 2009 | Samsung ML 2010 Laser Printer
Every time I print, the printer feeds an extra blank page after every printed page. How do I get it to stop this?
I have an HP D7360 Photosmart that has been doing the exact same thing. This has been driving me crazy, especially when I have to print a lot of pictures at once or a long report.
After uninstalling and reinstalling the printer a dozen times, installing every possible driver I could find for it, and even swapping out the USB cable (who knows...stranger things have been the cause of problems!!), I just found the fix for this.
Go to the Properties page of the printer (for mine, I open the printer, click "Printer", then select "Properties"), then go to the Advanced tab. At the bottom are a few checkboxes, one of them being "Enable advanced printing features". I unchecked this and do not have the problem with the extra page.
I am not really sure, at this point, what else may be turned off, but just printed a test page and WOOOHOO...no more blank page came out right after it.
Hope this helps you and that the "advanced printing features" aren't something that negatively impacts your and my ability to print quality pictures and documents.
I love this printer otherwise. Amazing picture quality!!!
Apr 09, 2009 | HP Photosmart D7460 Printer
HP 2410 printer won't boot up, just makes a clunking sound.
Someone just had a similar problem.
Unplug your printer for a few hours.
Plug it back in and the problem clear.
Jan 29, 2009 | HP Photosmart 2410 All-In-One InkJet...
1020 PRINTER DRIVER HP
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Jul 14, 2008 | Office Equipment & Supplies
HP Deskjet 3845 InkJet Printer Logo
Clive
Clive
