Question about LG LA185HV Split System Air Conditioner
LG Artcool Error Code C1. What does this mean? (Background info A/C unit works fine, cools as normal. Installed 2 years ago)
  • 2,133 Answers
Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Posted on Jan 01, 2011
  • Ionut Hornoiu
    Ionut Hornoiu Apr 10, 2012
    C1 error code means Faulty coil sensor. Replace the coil sensor.
  • Imran khan Jun 05, 2017
    Outdoor unit not on
What does c1 or cl mean on a artcool lg air con
Usually its a temp issue, the temp sensor is freezing up. Try removing the front part with the air filter in it and clean everything, also clean the coils on the outside as well to make sure theres good airflow. If that doesn't do it there isn't much else you can do as far as servicing them, it will have to go to a repair shop for further work.
Jan 11, 2018 | LG Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
LG Artcool about 4 yrs old error code CH 05. no heating or cooling. cheers.
CH 5 on these machines indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assy to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts stockist.
Jun 16, 2011 | Heating & Cooling
C1 error on lg 18 artcool
C-1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace
Dec 11, 2010 | LG Heating & Cooling
Hi! lg 18 artcool show on indicator panel the fault " c1 " not 'ch1' , it is air sensor ?
C1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace
Dec 11, 2010 | Heating & Cooling
Lg muilty system midwall unit error code c1
sensor
Nov 02, 2010 | LG Art Cool LA181CNW Split System Air...
I have a LG Artcool LAN121HNP the unit will only ciculate air (not cool) it is only 2 years old. I have had an HVAC guy look at it, he says the compressor is fine. We have put a new board in the outside...
Make sure none of the thermostat wires from the inside unit to the outside unit have come loose or have be cut by a weed eater or such. These units are a little more complex than your average heat pump.
Aug 24, 2010 | LG Art Cool LA181CNW Split System Air...
LG LA185HV Split System Air Conditioner Logo
4,231 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
