Question about Sunbeam 5891 Bread Maker
The 5891 has an O-ring seal inside that helps secure the pan when inserted. This seal came out and as a result the pan wobbled back and forth during the kneeding cycle and, I believe, caused the spindle inside the pan that rotates the paddle to become frozen so that it does not turn. I'm looking to buy a replacement seal and pan but haven't seen these offered as replacement parts online--I have only seen the paddle being offered. Are these parts offered or, is it just better to buy a new unit ?
    Genius:
  • Sunbeam Master
  • 1,280 Answers
Hi, I have looked to expecting to find one but ran into the same thing you did. I didn't try Sunbeam Oster though, maybe they would have one. I buy and sell and repair bread machines sort of as a hobby. If you ebay, I have a cuisinart and your model of sunbeam up for sale this week. If you ebay and are interested in just getting a replacement machine the one I have advertised has never been cooked in so the pan is new. If you ebay just type this Item # in the ebay search bar:
260688801609
best wishes and happy breadmaking!
Posted on Nov 08, 2010
Can the insert be replaced that is inside left panel ?
yes,go to home depot or Lowes and explain your problem to them and they will put you in contact with some that can help at the store level.
Jul 22, 2014 | Hillsdale 1104-010-020 Dorchester Daybed -...
I have a Sunbeam Breadmaker Model 5891 and I need a new bread pan; it's dented and the seal around the paddle is worn out. Where you one purchase them?
goto the amazon website the bread pan is there and also bread kneeder thats £6.05 EACH THE LAST TIME I LOOKED TWO WEEKS AGO
Jan 20, 2011 | Sunbeam 5891 Bread Maker
Looking for a replacement rubber gasket for my Sunbeam 5891 Bread Maker. It goes between the bread pan and the machine itself, and my current one is split.
Hi..If you are referring to the gasket that sits on the bottom of the bread pan and is part of the sealed bearing assembly , then that gasket can not be replaced. Hank
Sep 22, 2010 | Sunbeam 5891 Bread Maker
How do you change the oil in a 2005 sunfire
FIRST OF ALL YOU NEED 4.0 QUARTS OF OIL FOR 2.2L 2.3L AND 2.4L OHC ENGINES AND THE 2.2L OHC USES 5.0 QUARTS WITH NEW OIL FILTER.TO GET START YOU NEED A FILTER WRENCH,DRAIN PAN, RUBBER GLOVES WHICH PROTECT HANDS FROM OIL. OILWILL CAUSE CANCER , IF STAYS ON SKIN TOO LONG.YOU NEED TO CRANK ENGINE UP LET IT IDLE 5 MINUTES TO THIN OUT MOTOR OIL SO IT CAN FLOW FASTER.WHEN 5 MINUTES UP.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS ON SOLID LEVEL GROUND.SLIDE DRAIN PAN UNDER THE CAR OIL PAN. PUT ON RUBBER GLOVES THEN REMOVE OIL PAN DRAIN PLUG ON BOTTOM OF OIL PAN USING A 15 METRIC SOCKET WITH RATCHET WRENCH.WHEN ALL OIL DRIPS.SCREW IN TIGHTEN OIL PAN DRAIN PLUG BACK IN OIL PAN REMOVE OIL FILTER ITS NEXT TO OIL PAN USE SOCKET TYPE OIL FILTER WRENCH IF OIL FILTER IS DOWNWARD POSITION. IF OIL FILTER ON THE SIDE YOU NEED THE BAND TYPE OIL FILTER WRENCH. ****** NOTE THIS THE 2.2L OHC ENGINE USES A OIL FILTER ELEMENT THAT HOUSED INSIDE A RECEPTACLE LOCATED AT THE LEFT FRONT CORNER OF THE ENGINE.YOU UNSCREW THE OIL FILTER CAP THEN LIFT THE CAP AND OIL FILTER FROM THE FILTER RECEPTACLE IN THE ENGINE.SEPERATE THE OIL FILTER ELEMENT FROM THE CAP USING A CLEAN RAG REMOVE OIL DIRT AND SLUDGE FROM THE OIL FILTER CAP AND FROM THE RIM AROUND THE OIL FILTER RECEPTACLES.INSTALL A NEW O RING INTO THE GROOVE IN THE CAP.THEN INSTALL THE NEW FILTER ELEMENT IN THE CAP AND INSERT BOTH INTO THE FILTER RECEPTACLE.SCREW DOWN THE CAP AND TIGHTEN IT SECURELY. WHEN ALL IS DONE POUR NEW OIL IN CRANK CASE.MAKE SURE OIL LEVEL ON DIP STICK ON THE FULL MARK YOU CRANK THE ENGINE.MAKE SURE OIL DRAIN PLUG SCREWED BACK IN OIL PAN.WHEN INSTALLING OIL FILTER FILL IT HALF WAY WITH NEW ENGINE OIL,RUB OIL ON FILTER SEAL TO HELP IT SEAL TO ENGINE.BESURE WIPE OIL FILTER SEAL SURFACE ON ENGINE TO MAKE SURE IT CLEAN. WHEN ALL IS DONE CRANK ENGINE UP CHECK FOR OIL LEAKS.IF ALL IS GOOD LOWER CAR BACK TO GROUND,YOU DONE.
Sep 16, 2010 | 2005 Pontiac Sunfire
How to lube and seal the bread machine shaft assembly
You can not reseal the sealed bearing that is on the bottom of the bread pan. Bread pan needs replacement. Try Amazon. Hank
Aug 18, 2010 | Sunbeam 5891 Bread Maker
My problem lies entirely on wear worn out parts on the Sumbeam 5891 bread pan. The bushing is worn enough to leak. The coupler on the bottom has a partially worn "wing". I've read that there is suppose to...
The sealed bearing is pressed in on the bottom of the pan and individual parts can not be purchased separately. You need a new bread pan. Try a google search or try eBay. This is a popular model. Hank
Feb 22, 2010 | Sunbeam 5891 Bread Maker
The container that bakes the bread has a tab on the bottom that turns, and is on a shaft that goes thru the bottom, and this shaft is held by a snap-ring. we can't get the tab off,(supposed to come off to...
Thank you for visiting Fixya. The tab you speak of is called the paddle. The paddle sits on a shaft that is pressed into a sealed bearing. This shaft is not supposed to move in the bearing. If the shaft moves the bearing will lose it's seal and lubricating fluid (oil) will leak out. The snap ring, bearing, and shaft are put together before they are installed into the pan. If you can't fit the ring back onto the shaft so the shaft doesn't move, then you should hunt around for a new bread pan. P.S. Putting soapy warm water in the pan and letting it sit for a while will free up the paddle so it lifts off the shaft. Also lubricating the shaft with a squirt of olive oil will help stop the paddle from sticking on the shaft. Good Luck...Hank
Nov 28, 2009 | Zojirushi Kitchen Appliances - Others
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Breadman TR2200C Ultimate Bread Maker pan leak
I was finally able to find a same size of heavy duty shaft seal from McMaster-Carr and installed on the pan with liquid weld after greased its inside. I put an extra washer on the shaft as well since the shaft itself was worn a little and wobbled . I needed a new snap ring to secure the spindle in place. Old one was rusted and disappeared.
Our bread machine is now back to work and we enjoy having a tasty bread every morning again.
Mar 26, 2009 | Breadman TR2200C Ultimate Bread Maker
Sunbeam 5891 Bread Maker Logo
294 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
