Question about Mitsubishi WS-65807 65" Rear Projection Television
I have a Mitsubishi WS-65807 65 in. Rear Projection Television and the images are now showing in 3 colors blue green red and looks hour glass shaped on the left hand side of the TV if your looking at it. How can I ffix this?
    Problem Solver:
  • 16 Answers
Your convergence circuit has failed. The amps need to be replaced but most likely the resistors have also been weakened or have opened up. The other issue with doing this repair is getting the correct parts. You can go online and order them but in most cases you will end up with generics. Generics in the electronic industry are not like in the pharmaceutical field. Stay away from generic IC's and other generic electronic parts. Even if they fix the problem they will cause issues with resetting the computer parameters or they will fail premature. If you know an honest technician let them do the repair. If you put all the parts back in a can't get it aligned you will need someone to go into the computer anyway. Just make sure the tech is using original Sanyo amps and not generics. An easy way to tell is the originals don't have any numbers stamped on the back(heat sink area)of the IC.
Joe
Posted on Nov 08, 2010
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have and 65" Mitsubishy HDTV model WS-65511 serial :118393 I never had a problem before but las week i was watching a program and sudenly a second blue image was on the scrren, i decided to open the...
there just might be a slight chance an adjustment of g2 high voltage to the blue tube might help however there is a good chance there is a problem with the tube
Oct 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Yellow, blue and green ghosting of picture. Convergence mode will not allow realignment of the red and blue lines
Hi,it sounds like a light engine problem.Lcd Technology uses 3 chips blue,green and red that create the image ,when they start to fail color discoloration will occur.If it's an Dlp pay attention to sounds of buzzing,whirling and high pitch sounds because it could be your colro wheel.
Oct 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65908 picture problem
since this happened after you moved i would look for loose connections on the convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red / Green issue when connecting Mits DVD to Mitsubishi TV
Convergence problems, look in menu and find manual conver. and read for more info goto ctechnicians.com
Dec 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
if you just moved it i would look for loose connection arouind the convergance amp ics
do not play the tv....
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Mitsubishi WS-73905 73" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
