Question about Solis Master 5000 Espresso Machine
I have the manual unit and this morning after making a few capps it went to grind and then just stopped. I turned the unit off and then back on but the unit did not do its normal 'first' cycling. I have the power light but the unit acts dead otherwise. I can tell that the unit is heating up, but otherwise . . . I'm assuming I've lost the motor. Is there an internal fuse? What should I look for to isolate the problem and get parts to repair? Thanks, Ty
  • 1,089 Answers
Check for something out of place. Brew unit, dredge drawer, driptray. There is wires on the boiler that may have come off, but unlikley. It could be the brew drive motor, or the board.
Posted on Nov 08, 2010
  • ty_wood53 Nov 08, 2010
    Thanks for the reply - I went back to looking at it after your response and when I turned it on it functioned normally? I don't know if it just over-heated (that's never happened before) or what. Anyway, at least for one more capp all was well - thanks again.
Turned off this morning then when went back to sew project it wouldnt sew,no funtionality Everything is lit up. Turned off waited a few sec. Turned on. Nothing Is there a reset button?
Difficult to help without knowing the make & model. Try the Troubleshooting section of the owner's manual. Otherwise, try contacting a local dealer or the manufacturer support number.
Sep 26, 2016 | Sewing Machines
Why wont my 2005 Chevy Silverado 1500 go into drive or 3rd, but will go into 1st and 2nd and reverse?
There is definitely something horribly wrong inside the transmission. Get it serviced immediately. The longer you wait, the more damage will be done.
Mar 18, 2015 | 2005 Chevrolet Chevrolet Silverado 1500 LT
Rheem RPKA-030JAZ MAKES A HARD KNOCKING SOUND
sounds like it's running backwards. possibly need a time delay in the condenser. make sure your drain line is clean.also inspect low voltage wires for bare/ chew spots near outdoor unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 12, 2017 | Heating & Cooling
3rd master hard drive disk error
If you have the instruction manual etc or get it with another computer try getting into the SAFE mode to trouble shoot this issue.
Jun 13, 2012 | E-Machines eMachines Desktop PC
I was driving to work this morning and was in 3rd gear, went to down shift at a stop sign and its stuck in 3rd gear. 1988 jeep wrangler. It has been grinding the gear for a few weeks now everytime I change...
The 3rd Gear Synchro is worn or damaged, which is why it grinds when you try to upshift or downshift into 3rd gear. When it goes out completely you will have a very hard time shifting into 3rd gear, since the Synchro lines up the gears to make shifts smooth and easy.
Aug 24, 2011 | 1995 Jeep Wrangler
My dryer is squeeking and grinding, but not all the time. What could be wrong? When it first starts, it sounds like it is grinding, but continues to work. After a few minutes, it stops. Then it will start...
One of two issues is going on, or maybe both. The first cause for the grinding noise is going to be the main bearing that is bad, and needs to be replaced. The squeaking is actually coming from the belt. So I would check under the unit and make sure that you do not have any metal shavings under the unit. Then also check the belt
May 18, 2010 | GE DBL333EA Electric Dryer
Stopped working
What is the make and model of the unit in question?
- J
Feb 12, 2008 | LG KU990 Viewty
Solis Master 5000 Espresso Machine Logo
93 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
