I'm having "speaker hum" issues
  • 1 more comment
  • Jerry Goggins Nov 08, 2010
    That's great news about replacing the capacitors to eliminate the speaker hum. I have some experience with electronics, but let me ask the question: I assume that these capacitors are attached to the power supply of the amp...is that correct? Are they reconnected by soldering?
    I took the cover off of the RCA amplifier, which is a model RT2400R, SN 947200233. Could you tell me which of the capacitor(s) would likely be the cause of the speaker hum? I've enclosed a high resolution photo of the inside of the amp, which you could use to identify the likely failed items.
    I did some research on the appearance of failed capacitors. None of the capacitors in the amp show any sign of failure.
    If I can't replace the capacitors, then I'll probably need to replace the amp.
  • Jerry Goggins Nov 10, 2010
    Actually, I finally decided to replace the amp entirely. I had previously disconnected everything (cable, TV, and DVD/CD player as well as the incoming cable signal) and connected only the old amp and still had the hum. Your other technician's suggestion-to replace all the capacitors in the old amp-was something I was prepared to try, but I was able to get a new Onkyo unit for less than $200. The Onkyo has features that I do not have on the old amp (A + B speakers, a better tuner, and HDMI connectors, among others.)
    Your company does a great job on these inquiries. If I have hum problems with the new amp, I'll get back to you. I'll leave this issue open for the next week or so.
    President:
  • 1,851 Answers
The possible problem at your case is a "ground loop". Although you didn't mentioned all the devices on your system, let's try to solve it. Unplug every mains power socket from the mains and isolate the ground connector so that can not reach the mains ground connector (sorry but I don't know where are you from, for example if your mains power plug is a "shuko" type, use isolating tape over the ground metal on both sides). This has to be done on every device power connector; not at the mains power cable that is connected at the wall socket. Check the results. Usually this trick works in order to elliminate the "ground loop effect" that is causing this low hum that you can hear to. If this solves your problem I suggest you to either use the isolation tape on all devises' power sockets except the amplifier (that can be connected with the right way) or use a custom made multi power socket without using the ground connectors for all the devises except the amplifier.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Nov 09, 2010
  • 11,800 Answers
It's the hum of the mains: the electrolytic capacitors inside the power source of the amp have aged, they dried so their capacity has lowered so they are no longer capable of filtering the current properly.
No need for a new amp, just replace the capacitors - less than $25 for all of them.
Posted on Nov 08, 2010
  • 1 more comment
  • Azrael SRL Nov 08, 2010
    Yes, they are soldered in there. Make sure to get identical replacements.
  • Azrael SRL Nov 09, 2010
    The capacitors didn't failed, they AGED - normal behaviour. They aren't defective, just that with the passage of time their capacity has decreased so they can't filter the current as they used to. You should replace all, it's a cheap and easy fix.
  • Azrael SRL Nov 10, 2010
    In that case please don't forget to select the answer that helped you most.
Woofer is humming
Usually a faulty cable or blown speaker will cause a humming. If it is a constant humming I would surmise a faulty cable. On the other hand, if the humming comes and goes I would guess a faulty speaker.
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
When switched on a humming sound comes out of all speakers,no audio can be heared when a cd is played.
check all jack plugs are in the correct places and speaker connection wires too.try turning your tuner on to test the speakers that way for sound,if sound is heard through the speakers it could be a cd malfunction.if nothing works contact your dealer.
Sep 03, 2011 | Eltax Nova Theater System
My center speaker is humming after i turn the tv on.
If you center speaker is humming, you when you turn on your TV, you may have the audio signal over amplified and the hum may be coming from your TV itself. Try moving the speaker further away from the TV or the amp further from the TV and see if it solves the problem.
May 24, 2011 | Coby DVD765 Theater System
I turned on my home theater sc-ht670, and the display shows "hello", "init ", "please" and finally "wait" and nothing happens and be left with the word...
Basic steps to check if the problem lies with the home theatre system or not.
1. First thought might be to conclude that your poor audio quality is caused by your speakers, before you immediately race out to purchase a new home theater surround sound speaker package, check the basic things first.
2. The problem might not be in the speakers, but in the amplifier or the connections from the amplifier. Checking and ensuring that the speakers are correctly connected on both ends is the first step.
3. After the connections pass examination, the next step is to check if the problem lies with the amplifier or audio speaker. Some of the lower end home theater systems come with low powered amps. Most often they do not supply sufficient power to speakers to produce the quality audio you desire. This may show up particularly if the room is large when the sound doesn't fill up the room.
4. To determine if it is indeed the amplifiers then hook up your speakers to a stereo; this generally will have a more powerful amp. If the speaker quality improves then the problem probably lies in your home theater amplifier.
If you cannot distinguish any difference, then your speakers could possibly be at fault.
5. Poor cable installation and audio speaker cable are another possible cause for consideration. Cheap workmanship can lower audio quality and home theater packages often come equipped with inexpensive poor quality cables.
6. If you experience problems with your theater system, it is always best to assume the problem lies in the connections between components first and then suspect the components themselves.
7. To ensure a great sound experience ensures that everything is properly connected, your amp is of sufficient power, and the cables are of high quality. If a person makes use of these basic easy precautions a significant amount of frustration can be eliminated. If your home theater sound isn't where you need it to be, use those hints as a blueprint as you analyze your system. If it really is time to look for new components, consider those directives as you make your next purchase.
Note : Check to see if the color is bad across all input sources. If so, make sure you have your Televisions' color settings set to your preferences. If everything looks good except, say, your DVD player, and it is connected to your TV via Component Video Connections (which is composed of three cables - Red, Green, and Blue), make sure they are matched up correctly with the Component (Red, Green, and Blue) connections on your TV. This is a common mistake as it is sometimes hard to distinguish the Green and Blue connectors if the lighting in the connection area is dim.
Mar 21, 2011 | Panasonic SC-HT670 System
When turning up the volume speakers start to humn. Tried on all inputs still humming. Sound comes out but humming is there. Humming only stop when turning the volume all the way down.
You need to add a "ground lift" to the power cord to your system. What you're hearing is a 60 cycle hum (electricity) from house power.
Mar 11, 2011 | Philips MCD-735 System
Had someone from Best buy set up my new Sony bravia 47 in LCD TV. He said I should not use my slightly older Bose Cinemate digital home theater speaker system with the newer TV because the speaker system...
Hello,thats a first and he is completely wrong.The sound will arrive at the stereo at the same time it arrives at the cable box or the tv,depending on what source the stereo is hooked up to.Without going too in depth he is referring to center channel delay which is a feature in some home theaters created to induce a delay when its required, most notably when a projector is used.
Feb 20, 2011 | Bose Cinemate Digital Home Theater System...
Loud hum when I turn on power from the speaker
Disconnect the device (amp or TV) that is feeding the speaker system. Turn on the power and see if there is still a hum. If the hum is no longer present, then the hum is most likely from the source.
If the hum persists, most likely the power supply has failed, or the output section has a short. You should contact the manufacture for support. They will most likely recomend that you give the unit in for service.
Jerry G.
Feb 09, 2009 | Coby 5.1 Channel DVD Player with Home...
Rca home theater system reciever makes noise when turn on
is it a humming noise, or a high pitch noise, and is coming from the speakers or the receiver?
Jul 21, 2008 | Audio Players & Recorders
Hum coming from speakers
Faulty wires/ connections are the usual cause of hums on speakers. Try checking if the wires are properly connected. If it still hums, try replacing the wires with a known good wire.
Nov 20, 2007 | Audio Players & Recorders
Hum & noise coming from the speakers
IF it was too load you probable blew the speaker Just disconnect the side that is making noise or is it both side?
Oct 16, 2007 | Coby DVD-937 5.1 Channel DVD...
67 people viewed this question
 Grubhead
Grubhead
