Question about Logitech Z-560 Computer Speakers
Logitech Z-560 Left Channel died
My problem lies in circuitry and not the computer, because all 3 other channels work when with an ipod or signal generator. Swapping speakers and wires makes no difference. If I had a schematic I could probably figure it out but where would I find the parts like the Power output module? I don't see Logitech having support for out of warranty items, unless I'm missing something. Note: There are no crackling or problematic noises stemming from pots, connectors, cables or even shaking the sub or moving the Pod cables. My problem may exceed the limitations of this forum but if anyone has anything to offer (other than cold solder joints) I'm all ears.
  • Anonymous Nov 16, 2008
    same exact problem but one channel doesn't work at all and the other is somewhat distorted and the lyrics are faint and almost inaudible.
The fuse is inside. Remove the screws from the back, around the outside only. Pry it up and it will pop off. It is a bus fuse 4amp 250V. Disconnect the sub from everything. After I replaced the fuse I pluged it in. When I turned the switch on the fuse popped. At $50 an hour to repair I decided to replace the whole unit at a price for $80. Here is a link http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2507686&csid=ITD&body=MAIN
Posted on Dec 17, 2008
How do I put it on channel 3?
If you are asking about using a standard CRT Monitor with some device that has a Channel 3 TV output, you have to either have a tv tuner device between your monitor and the device you want to connect to, or find video outputs on the device other than the TV channel out in order to connect to a monitor. Monitors work with video signals. TV's work with radio signals. These two inputs are not the same thing. Channel 3 is a specific radio frequency signal that must be converted to video to be displayed by a TV. Computer monitors do not have the circuitry installed to convert radio frequency signals to video. Therefore, strictly speaking, there is no easy way to 'put' a CRT Monitor 'on channel three'.
Apr 25, 2015 | Televison & Video
Creative SBS 370 2.1 - left audio channel is not working
This is coz of one carbon track of dual potmeter gone bad due to prolonged use.
Jan 28, 2013 | Creative Labs SBS 370 Computer Speakers
I can't find the Timing for Crucial PC3200 DDR 400mhz
Sorry to run dual channel memory both stick MUST be the same
Aug 19, 2008 | Intel Motherboard
Drop out of left channel, Adcom GFA5802
It sounds as if there is a broken solder joint somewhere that slowly opens up with heat. The other possibility is that an input or driver transistor is dying. Since the whole channel is dying, I would guess the broken joint and/or dying transistor are near the very input of the channel.
A tech can very easily find the spot by playing the amp until it starts to die, then spraying small bursts of freeze spray, one component or area at a time, until the amp suddenly comes back to life.
Aug 13, 2008 | Adcom GFA-5802 2-Channel Amplifier
Front Right Signal to Front Left Speaker
It is a problem with mixing sound, DX9, or CMSS for 6.0 speakers, try reseting the creative diag. or change the PCI card on another slot.
1) verify connectors.
Jun 15, 2008 | Logitech Z-560 Computer Speakers
CHANNEL DISPLAY
I had the same thing happening. 20.1 was 19.1 as well as 12.1, 12.2, and 12.3 were 38.1-38.3. In the last couple of weeks my tv has freaked out and died. I'm just passed one year so I think I'm screwed. I looked and it has corrosion on both boards. That might explain why the logic circuitry didn't work right. Maybe not. As a computer builder though I know corrosion is a bad thing.
Jan 02, 2008 | Polaroid FLM-323B Television
Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Dec 31, 2007 | Audio Players & Recorders
Channel not working
If the Logitech Pulse 475 is the same as the Labtech Pulse 475 then the left channel amplifier probably blew. The Labtec uses a 5 pin TDA2030A, which costs around $3. You will need to know how to solder to repair this. The back of the case comes off by removing the 8 screws around the back of the case and lifting it out by the power cord. Then, simply desolder the left channel amplifier marked IC201 (it's on the leftmost side of the board, next to the volume potentiometer) and solder the new amplifier in it's place.
Jun 19, 2006 | Logitech Z-680 Computer Speakers
Logitech Z-560 Computer Speakers Logo
669 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
