Question about Ruud Heating & Cooling
RUDD A/C not running, only fan
I had a RUDD unit installed last year at a condo at the beach. We arrived tonight and only the fan is running. When I go to look at unit outside, it isn't running. We've looked at the fuse box and thought of any way it's not getting power but can't figure it out. I'm sure the last time it was turned on because we do not rent the unit and were here last month but it was still cold and we didn't use it. HELP...we are burning up!
Thanks!
AC Unit humm but fan dosnt tun on unit. I turn the power on and off and can hear it click. Help???
Posted on Jul 05, 2008
    Scholar:
  • 149 Answers
Ok it unit is a central I'm suspecting a voltage transformer is defective you see these units need 24v to turn on certain components but if your air handler turns on, your getting 24v to the fan relay, the problem would be elsewhere. if your handy with a volt meter open the thermostat(if applicable) put the meter on ac volts and measure to see if there's 24v between the R and Y terminals
if so your cooling contactor is defective. (If you get 24 v and unit outside dosen't turn on) if there isn't some fuse on the air handler control board blew out.
you can e-mail me @ hvac.tech7872pr@gmail.com if you need more info
Posted on Jun 16, 2008
A/C compressor noise
It may be your contactor.
May 31, 2013 | Heating & Cooling
I have a 6 year old Rudd heat pump.The AC would run for a while and the compressor would shut down until I pushed the reset button.An AC contractor came out and looked at the unit and bypassed the reset...
The reset button that he is talking about is probally the high pressure manual reset. There are reasons that this can trip.
1. Dirty condensor. 2. Condensor fan motor not up to par. 3. A liquid line dryer that is partially blocked. 4. A metering device that is not feeding right. If he verified all these and it still tripped maybe a bad switch. Anyways, with it bypassed what ever problem that is causing it to trip is still there and will get worse and the compressor will burn up and he will come and put in a brand that he likes. Hope this helps.
Jun 01, 2011 | Heating & Cooling
We have a sub-zero refrig/freezer that came with our condo. Condo built in 1985. We purchased 12 years ago and were the 1st owners. This was originally the model and not lived in but very rarely by one of...
After 12 years you can expect that kind of repairs...I would not spend the 1200 for the compressor and would instaed replace the unit...it will just irritate you more from here on...
heatman101
Aug 30, 2010 | Kitchen Ranges
I have a RUDD Achiever 11. The outside fan only intermittently runs and seems to quit in the evening (overtime for the air condo techs). It won't start again until the morning but when it runs, it blows...
Two possible problems here.
1. you have a bad condenser fan motor. average cost $140.00 for the part plus installation if you can't do it. just buy the motor you most likely will be able to use the existing fan blades.
2. you have a bad run capacitor on that fan. avg cost $5.00 - $35.00 plus installation
In my opinion if you're handy and safe with electicity save some money, if not have it done.
check out grainger.com for the parts they're very reasonable. for the fan you'll need to get specs from the defective unit like amp. voltage rpm. its all on the unit itself. for the run capacitor you'll need the same. all the info u need is on the parts. search the site for run capacitor or condenser fan motor.
good luck hope this helps
Jul 15, 2010 | Ruud UBHC Air Conditioner
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="http://mojaizba.com/convert-units-of-flow" title="Flow units converter page on mojaizba.com - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute cu.in/min, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
Has not ever run properly
is it a heat pump? I would be suspect of the line voltage transformer have 24v. if transformer is not matched to line voltage you can have erratic problems their is an under lying problem. that is being missed find a good contractor . Tom
Jun 17, 2009 | Ruud UBHC Air Conditioner
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
Heating & Cooling Logo
128 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
