Question about Heartland 621003WB05 Range
We have a Heartland 4120 electric range. Heating element on bottom burnt out. We replaced it but wouldn't heat; the reset button located underneath the oven cannot be reset.
3 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Posted on Nov 12, 2007
  • 96 Answers
SOURCE: how do you replace the bottom oven element on a
For model numbers that are not listed below, please call our toll free number at 1-877-650-5775 to order the appropriate manual sorry this is all I could acquire.
Posted on Mar 07, 2011
I have a 36 heartland range and the oven does not work.I have reset the breaker and then it works.there was sparks before,i think that the electric element was out of the clamp and it ground on the fire...
It is possible you have shorted the element out or burnt a wire in half.
Not sure about another fuse but I suspect something is burnt out.
Just a thought
Feb 18, 2015 | Heartland Kitchen Ranges
How do you replace the bottom oven element on a Model 8100 heartland electric range maybe
Mar 06, 2011 | Heartland 621001WB02 (Electric) Kitchen...
The oven was on and I was baking. Heard a 'pop' then the oven went off. I flipped the stove breaker on my electrical board back on and it took the whole power to my house out. Flipped the stove breaker...
element has blown, pop is it breaking, that heating element will need replacing, failing this and elements all working water may have gotten to the electrics this would cause the pop and shut down all electric as well.
Jan 02, 2018 | Heartland 3525SS Dual Fuel (Electric and...
I have a 36" heartland range and the oven does not work. A few times I have reset the breaker and then it works, although now even that does not work. The gas top works fine ande the digital display unit...
If you had to keep resetting the breaker that means the electric element was shorting, arcing and therefor drawing too much amperage. The reseting of the breaker kept allowing it to spark start. The high voltage would occasionally create its own bridge from the heat expansion to make a connection and work. But the use of the unit under these conditions kept destroying the heating element even more. A few things need to be checked now. The heating coil, and the high voltage wires inside and out. There is no telling where the damage may have traveled now. Hopefully it only killed the heating coil.
Mar 18, 2010 | Heartland Metro 3635RWNG4PR Dual Fuel ...
Burners are working oven is not working ?
The heating element may be burnt out, you will need to replace this element if it does not heat up when the oven is turned on, try turning the oven to broil if the top element heat up then indeed it is the bottom element and need replacing.
Dec 18, 2009 | KitchenAid KESC300 Electric Kitchen Range
IT WILL NOT HEAT. how do i remove the heating element to replace
Is it gas or electric? It could have a bad timer, heating element, power problem, circuit breaker could have tripped, or blown fuse or burnt wires inside dryer. I believe the top pops off from inserting a screw driver between the top and front dryer frame and pushing in 2 clamps located near each side. Then the front unscrews from the inside. Or a bottom panel might come off same way underneath the door.
Sep 16, 2009 | Dryers
My frigiaire stove element started sparking and caused smoke;called tech. Is this a common prpblem and subject to recall
Hi, yes, it's happened sometimes, to all electrical heating appliances, yes all heating elements, sooner or later will burnt out. better quality ones, will last longer, but will burnt out too, always replace with original (FSP) factory specification parts, from manufacturer.
Aug 07, 2009 | Frigidaire FES367 Electric Kitchen Range
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
One of the dual element not heating up on a smooth top electric range
If this section was working before then it is either a defective switch or there is a burnt out section in the heating element - more often than not its the latter - the heating element would have to be replaced
Regards
Sep 22, 2008 | KitchenAid Kitchen Ranges
Heartland 621003WB05  Range Logo
102 people viewed this question
Top Heartland Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Heartland Kitchen Range Expert? Answer questions, earn points and help others
