Question about Canon BubbleJet i905d InkJet Printer
My Canon i905d printer came up with error 5100 and will not print. I managed to clean the printhead and now it comes up with error 5200 and still won't print. It also says No printhead installed!
  • 2427 Answers
SOURCE: Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Posted on Mar 23, 2010
Tinteiros
  • 85 Answers
SOURCE: CANON MP830 all in one is sayin" the type of printhead is incorrectn Install the correct Printhead."
Hi follow the instructions as above...
ie Remove inks and print head...
But instead...
Whilst Canon print head is out...
Use cotton wool and alcohol and clean electrical contacts on back of print head and where they make contact inside printer.
Then install print head and inks and test.
If it does not work you may need to replace print head.
Posted on May 10, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
komguy
  • 2306 Answers
SOURCE: i have the error code 5b00 on my canon i905d. please help
The error code can only be reset by using diagnostic routines only available to canon shops.
Posted on Jun 30, 2009
SOURCE: CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Posted on Oct 29, 2009
Mx 316
Error 5100 typically means that something has jammed the carriage. Unplug printer, open, and examine the print area for anything that might be blocking the print heads from moving back and forth. clear...
Sep 07, 2014 | Canon PIXMA MP160 All-In-One InkJet...
On printing the printer Canon Pixma M350 has an error 5200
Error 5200 is an unexpected rise in the print head temperature. Canon's advice for this error is to replace the printhead together with the logic board. Not really a cost effective situation. I would replace the machine.
Srri
Jul 21, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Service Error 5200 comes up on printer status. What is the procedure for solving this error?
    5200 is a temperature error of the printhead. The only repair is a new printhead, you will find the part number on the side of the printhead, it starts with
    QY6-
    Jan 31, 2010 | Canon i9900 InkJet Photo Printer
    Will not print, shows error code 5200, says to ck printer, need more specific info, thanks
    5200 is a temperature error of the printhead. The only repair is a new printhead, QY6-0049-000.
    Dec 03, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Printer not working. The light flashes red six times.
    Error Condition Indicator Beeps Error
    Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
    Code
    Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
    Oct 01, 2009 | Canon S400 InkJet Printer
    Error 5200
    Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
    Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
    Canon i860 error code 5200?
    5200 is a printhead temperature error, defective printhead You need a new printhead,
    QY6-0049-000 around $40.00
    Aug 03, 2009 | Office Equipment & Supplies
    I560 error code 5200
    Cartridge Overheat 8 x
    7 times in orange/green 5200 Cause: The print head's temperature is abnormally high tnx and good day!!!!!
    Apr 07, 2008 | Canon BubbleJet i560 InkJet Printer
    Canon BubbleJet i905d InkJet Printer Logo
    338 people viewed this question
    old marine
    old marine
