Question about HP Photosmart C3180 All-In-One InkJet Printer
I have changed my ink and it saying i dont have any in it what can i do
Clour printing only clour working please help
not saying this will work for you,but what i do is switch off the printer to see if it will reset ,if that does not work i press the change ink button and just as it gets to were it should stop i switch the printer off by the main plug that stops it just were i can get to were i can change the ink.then i turn it back on again..dont no were your ink is but mine is just in the front of my printer i lift up the front panel and its right in front of me.
if you are not sure if you should do it that way then dont do it.
let me know how you get on.
Nov 20, 2016 | Office Equipment & Supplies
It tells me the cartridges are empty, then when i open the lid it says no cartridge! its not been used for a few months, and i refill them with generic refills...any thoughts? tried the switch off and on -...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Make sure that your ink cartridges are full and that they are genuine brother inks; refills or generic ink cartridges are not guaranteed to work properly.
Thanks,
Pat
Mar 29, 2010 | Brother MFC-620CN All-In-One InkJet...
How do I get the ink cartridges out of the mfc 290c???
its in the right frontal corner, there you can change the catridge, i got a problem too with Brother MC-290, it just keep saying CANNOT DETECT YELLOW INK REPLACE IT SLOWLY... this **** cant print just with the black one? ireally need to print something right now
Oct 04, 2009 | Brother MFC-290C Printer
Message on fax machine says change printer drum?
You need a toner cartridge which includes the drum. Go to a store like Staples, they will have what you need.
Jan 04, 2009 | Brother IntelliFAX 2600 Fax
My 2175 series printer is telling me to check print cartridges. I do that and then it tells me to close the door. It then repeats the commands. Do I just need new ink - they seem fine.I'm unable to print...
u can check the printer ink in printer properties..then dont open the door if u dont change the ink cause hp printer is automatic sensor...when u open the printer door the printer cartridge goes in center automatically...so if u dont change the ink close the door always
Sep 01, 2008 | HP Office Equipment & Supplies
My printer
sure....did you do a clean and alignment service after changing that black cartridge?
Aug 03, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Where do i change iht ink cartridge?
open the cover then the cartages will come in the middle then push it in frint side it will come and when you want to installed push it back
Jul 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
