Question about HP Pavilion dv9000z Notebook
HP Pavillion dv9000 does not show the presence of optical drive in device manager. Installing a CD results in the drive spinning up but nothing else- Ran the Microsoft FIX pgm ( MATS_RUN.dvd )- reports CD-ROM not recognized. So no driver or H/W recognition...where do I get a driver? Running WINDOWS VISTA 2007 -Service pack 2.
  • lorencbruce Nov 13, 2010
    Hi Dan,
    I fixed this problem via the following:
    1. Power down the DV9000
    2. Disconnect the DC power input
    3. Carefully remove the laptop battery
    4. Depress the POWER-UP button for 60 seconds ( discharge the PS caps )
    5. Reinstall battery and reconnect DC power
    6. Power up- CD-ROM now shows up in the device manager
  • 4,323 Answers
Hi
This is happening due to a driver issue. You can download the driver for your Optical drive from this link---
HP Pavillion dv9000 Optical drive drivers
Hope this helps.... Please post back in case you need further assistance.
Daniel
Posted on Nov 08, 2010
EMachines Desktop PC: when inserting a cd drive,nothing happens...
First thing to do is check whether your optical drive is visible in Device Manager:
Right-click on "My Computer" and select "Manage".
Click Device Manager, then look for a DVD/CD-ROM drives section on the right and expand it (click the plus).
If you dont see your optical drive listed there, or you don't have a DVD/CD-ROM drives section in Device Manager then your PC is not detecting the presence of the drive. In this case if it is a desktop PC you need to make sure both power and data cables are securely connected. If it is a laptop, you may need to just reseat the drive (due to its connector no longer making good contact with your mainboard). This would be a case of unscrewing the relevant screw underneath, pulling the device right out (possibly cleaning the contacts, if dusty), then pushing it back in firmly before putting that screw back in.
If on the other hand you DO have an entry in Device Manager for your drive but it has a yellow exclamation symbol next to it then that means there is a driver issue. This is commonly caused by uninstalling some particular cd burning software. It can be fixed by a simple registry edit...
Run Regedit (Start Menu->Run. Type "regedit", press Enter.)
go to "HKEY_LOCAL_MACHINE_SYSTEM \CurrentControlSet \Control \Class \{4D36E965..."
Delete the "UpperFilters" and "LowerFilters" entries. (These will get regenerated...)
Then reboot your computer. Hopefully problem solved.
May 18, 2010 | E-Machines eMachines Desktop PC
Can't get the Cd/Dvd drive to work, Windows vista doesn't show it in the device manager, I have a n HP Pavillion dv6500 notebook around 3 yrs old
If the device manager does not recognise the drive then it has most likely failed. You should be able to remove the drive, one screw on the underside, and reboot, Once you have done this power down, reseat the drive and power up again. If the Plug and Play software doe snot recognise it then you need a new drive.
Mar 09, 2010 | HP Pavilion dv6605us Notebook
Hello i'm having HP PAVILLION DV6000 and OS is
You first remove that device from device manager.
Then restart the pc.
You may check the BIOS menu for that device for any clarification.
After restart since u have removed it the OS will detect the device and install it automatically.
Hope this helped.
Jan 09, 2010 | Pioneer DVR-107D DVD±RW Burner
The cd burner in my computer just stopped working
if nothing working try to uninstall the driver and reintall it and see if that work if not need to change it...go to device manager and delete the device and restart the computer and see if it will load new one.
Nov 08, 2009 | Dell HP Pavilion ZE5000 ZE4000 NX9000...
HP pavillion DV6500 CD/DVD RW not responding, unit will try to boot up many times when system is starting but when I put in a CD or DVD no response and doesn't show a drive in My Computer. I've opened up...
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
If not than use Philip Screw Driver take out optical drive and put it back in Reinstall CD/DVD Drive drivers using Device Manager .
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 08, 2009 | HP Pavilion dv6000z Notebook
CD-RW driver disappeared
check the cable connections to your optical drive..it must have loosen up
Sep 05, 2009 | Acer Aspire 3050 Notebook
DVD drive does not show up in Computer drive list
Sounds like a cable or CD hardware issue. If you are comfortable taking apart the laptop yourself, disconnect /reconnect the cable or replace the CD cable. It's hard to update the driver if the system doesn't see the drive. Or, you could replace the drive. It's really hard to know which is the problem without testing.
Jun 13, 2009 | HP 419320-001 - HP Pavilion dv4000 Series...
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
HP CD/DVD optical drive is not recognized
I found that there was a firmware conflict caused by the installation of iTUNES. I uninstalled and cleared the upper and lower filters in the registry and the internal DVD-Rom is recognized. First I cleared the registry and the drive was recognized after a hard boot. So Far no twitches. Knock on wood.
Dec 26, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
1,276 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
