Question about HP Officejet 6310 All-In-One InkJet Printer
My HP Officejet 6310 All in One printer will not print from my HP computer
  • HP Master
  • 7,733 Answers
HP 6310 print problem-prints first 10 lines OK then next 10 are on a new page etc. Re-booting PC fixes problem.
Please check the Page selecton
check the page setup click on file -click on pagesetup
Press Ctrl+P
Check the layout settings
Check print priver if print privew is ok then its software issue
Check the printer drivers
DRIVERS HP Officejet 6310 All-in-One Printer
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
Tip
Solution for HP Officejet 6310 All-In-One InkJet Printer
Click Here!! For the most current drivers for your printer! Installing the newest drivers will let your computer talk to your printer! This will solve such problems as your page being printed out blank, and your computer not being able to "find" your computer.
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
on May 07, 2010 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6310 carriage jam
it require servicing if you can apply the any lubricant on the steel rod inside the printer it will fix your problem if it is not then i advice you to show it to service center.
Nov 13, 2009 | HP Officejet 6310 All-In-One InkJet...
How do I print a fax report on an HP Officejet 6310 All-In-One?
visit the following link to obtain the manual for your All-in-One. Hope this helps!
http://www.retrevo.com/support/HP-6310-Multifunction-Printers-manual/id/260dj484/t/2/
Sep 06, 2009 | HP OfficeJet 6310 All-in-One Printer...
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
For some unknown reason my hp 6310 has just started printing internet text (mapquest, orbitz etc) either very small (Joey's resturant menu) or very large (google map directions) any help, please.
Check if Hp smart web printing is installed in the computer.
Try uninstalling it.
also goto the printing preferences and check the settings there.
This issue can be fixed easily.
Thanks
Amit Verma
Hp AIO printers
May 10, 2009 | HP OfficeJet 6310 All-in-One Printer...
"NO SCAN OPTIONS" in HP Officejet 6310 all-in-one
You need to install the software and driver for the version of windows that is on the new computer.
Link to you model printer/scanner below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1119598〈=en&
Mar 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
Unable to print on my computer
Hello sir,
you go on HP Officejet 6310 All-in-One printer, double click on it, a small window will appear, delete all recent commands
if problem not solve then turn off your pc and printer both and unplug the U.S.B cable, now turn on the pc and delete HP Officejet 6310 All-in-One driver and restart pc then install the driver manually again and print your documents again.
thanks
Jan 14, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Problem HP OFFICEJET 6310
Make sure your that the printer is connected to the computer in a working USB port. Also make sure you have the correct drivers installed on the computer to be able to print using this printers.
Here is a link to your printer drivers:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1119598&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go
After you click the link, you will have to choose your current operating system. If this doesn't help, please let me know and I will further pursue a solution for you.
Jan 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Master Reset
I don't have a 6310 but I do have 4 printers one of which is a 5610. I never bothered w/ a reset switch because I would just turn the printer off, then unplug everying for 2min. Then I would reconnect everything back. If it doesn't work, I suggest you uninstall the software and reinstall it again. Let me know if this helps.
Nov 10, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
