Question about Frigidaire GLRT217TD Top Freezer Refrigerator
Freezer not freezing to coldest point - Frigidaire GLRT217TD Top Freezer Refrigerator
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 08, 2010
The motor seems to be running. Food is not staying completely frozen and I have it turned up to the coldest it will go. Freezer is 5 years old.
Hi, if you have turned the freezer to the coldest and the food is not freezing then you are lacking freon in the compressor.
You need to refill the compressor, besides the freezer is 5 years old.
Take care
Jul 14, 2010 | Freezers
Sidebyside freezer won't go on unless frig is put on coldest setting
is the freezer freezing things when fridge is not at coldest setting
Nov 11, 2009 | Heating & Cooling
Noisy refrigerator/freezer
The freezer fan motor , being noisey , is probably the cause for the food/drink problem . It should be replaced . Pt # 54482-10 is the part number for the motor . However , on your model , it looks like the bottom freezer panel , has to be removed , to replace the motor . The motor costs about $70.00 . Do not know if you should try this yourself , may need an experienced repairman , to remove the divider strip , to remove the panel .
Oct 11, 2009 | Refrigerators
I need to know what the numbers mean on the temperature setting (1-7) for my Gibson Upright Freezer? What is best recommended temperature?
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Oct 05, 2009 | Freezers
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Frigidaire GLRT217TD Top Freezer Refrigerator Logo
57 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
