Question about Datamax M-Class M-4206 Thermal Label Printer
We have just gone live on sage 1000 and are trying to print labels designed in sage paperless to send to our Datamax m-4206. Labels print but we cannot get the information to line up on the labels. Is there something we need to configure on the label printers?
  • 4 Answers
This can be caused by either the software, or the printer's electronic or mechanical settings. Software will usually override the printer settings for print speed, temperature, label dimensions, etc. In order to fully diagnose, I would need to know if the print is too high, too low, too far left or right, or skipping a label, etc.
Posted on Nov 18, 2010
What is the backing?
The Backing is the see through paper on which the labels are stuck to. It can have a light yellow or white color. While the printer prints, the labels move through the label sensor, usually green in color. The gaps between the labels triggers the sensor to indicate where the printer should start to print.
Hope this Helps. (",)
Aug 05, 2014 | Datamax DMX-M-4206 Thermal Barcode Label...
Can not find driver for a meto 4206 thermal printer? where can I get a free one
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Feb 07, 2011 | Datamax Office Equipment & Supplies
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
I need driver for datamax m 4206 e mark II
Jun 16, 2009 | Datamax M-4208 Thermal Label Printer
M-4206
Go to datamax web site and get DPL programmers manual
Nov 12, 2008 | Datamax M-4208 Thermal Label Printer
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Datamax M-4206 - error light whenever load or print labels
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked. Also verified that the sensor type (gap or black mark) in the software is correct.
Sep 09, 2008 | Datamax M-Class M-4206 Thermal Label...
Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Aug 25, 2008 | Datamax M-Class Thermal Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax M-Class  M-4206 Thermal Label Printer Logo
117 people viewed this question
Top Datamax Office Equipment & Supplies Experts
rongg
Johnathon Muise
Level 1 Expert
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
