Question about Frigidaire FEF336BC Electric Kitchen Range
My gas dryer is making a clunking sound on each drum rotation. It sounds like theres a shoe in it.
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Nov 08, 2010
The dryer made a clunk sound and the tumbler stop rotating
Sounds like you belt has either broke or came off. If you were rotating the drum by hand in the counter clockwise direction when it clunked, there is a pulley kit to fix that problem. If it was just running when it clunked the belt probably just broke. Hope that helps
Aug 29, 2011 | Samsung DV448AEE Electric Dryer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
I have a gas dryer - model #MDG9700AWW .. the power is on but when i push the button to start nothing is happening .. the dryer was recently making a sound like it would if there were tennis shoes in the...
do you hear like a click noise, it may have tripped your overload switch, it is located on the motor on the inside of the dryer. You will need to pull the front panel off and investigate. the screws on the inside of the door, pry up on the top corners, remove panel carefully as the door switch is connected to it, lift top lid back 90 degrees, look at belt, should be centered on drum and should be able to rotate drum with some resistance. there are two switches on the motor on resets the other trips, the rest will click when reset. Good Luck Tim
Sep 23, 2010 | Maytag Neptune MCG8000AW Gas Dryer
My Fridigaire gas dryer model gleq0642AS2 makes a clunking sound with every rotation of the drum. The belt is tight but there is some play (1/2 inch) at the front of the drum (door side). Not sure if this...
the bearing just slides of the spindle its a piece of plastic nothing sophisticated you might want to check the glides as well they are located on the front panel,open top panel take front panel off remove belt from idler pulley and pull drum on back there is a spindle with a sleeve bearing
Mar 20, 2010 | Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes clunking noise...almost sounds like a shoe is in the dryer
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 10, 2009 | Amana NGD7200TW Gas Dryer
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Dec 11, 2006 | Asko T781 Electric Dryer
Frigidaire FEF336BC Electric Kitchen Range Logo
251 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
