Question about Samsung HP-T4254 42 in. Plasma Television
Tv powers on for about 10 minutes then picture shuts off and relays are clicking. Hunted for visibly dead capacitors but see none.
    Problem Solver:
  • 16 Answers
How good are you with a soldering iron? This problem on this TV is usually the faulty connections on the SMPS. Most likely all the parts on the board are good but sometimes ICQ805 is also faulty(most likely it is just the solder connections). You can try heating one area of the board at a time with a hair dryer and see if it stays on for longer. Sometimes you have to heat then freeze to prove the malfunction. IMPORTANT: If you are not good with a soldering iron or don't have a steady hand, LET A PROFESSIONAL DO THE REPAIR. The SMPS is a very delicate circuit and can be easily damaged. If you do this repair incorrectly you will be forced to replace the whole board.
Joe
Posted on Nov 08, 2010
Samsung TV shutting off by itself and relays clicking
If you don't know what you're doing, don't open it up to fix it!
There are HAZARDOUS voltages on the power supply board EVEN WITH THE TV UNPLUGGED!!! The capacitors can hold a charge for several weeks!
Clicking noise can be coming from bad capacitors on the power supply board.
It's usually easier to just replace the power supply board.
Sep 09, 2016 | Samsung UN55B8500 TV
I have a Scott flat screen tv model# LCT39SHA It comes on then after few seconds or up to 10 minutes it shuts off.
There are two things you can do: open the TV and examing the power supply board for visually bulged capacitors and replace them yourself.
Or bring or send a board for service to someone who would do it for you, for example
http://www.coppelltvrepair.com/p/785/scott-lct37sha-power-supply-board-repair-serivce-for-totally-dead-not-powering-on-or-shutting-down-tv
There is also a third option, which is to just get a replcement power supply board. It's not necessarily bad one, but if it is an old and used board that has NOT been serviced and capacitors that tend to go bad replaced, then it will likely do the same in near future.
Aug 20, 2012 | Scott LCT37SHA TV
I HAVE A 42" PHILIPS
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem....
Sep 26, 2011 | Philips 42PF9630A 42 in. Plasma Television
TV plays for 10 to 25 minutes, then the picture shuts off, but the volume continue to play.
Since you have a picture for 10 to 25 min., we know that nothing is directly shorted. Look for bad connections in power supply and horizontal circuit or possibly bad capacitors in power supply.
Aug 13, 2011 | Hitachi 43FDX01B TV
The tv worked normally for a couple of hours and then clicked off, like in standby mode. when i switched it off completely and turned it on again it worked again but only for a short time. now only get...
Now tv turn on,pictures it flashes only a couple sec. than died have sound left only?Yes,than the tv power supply board,that the board where the tv power a/c cord plug into it.Board it might have dying and dead components parts that are called capacitors.Take the tv aparts.Inspect and check the tv power supply board carefully for dying and soon to be dead capacitors parts,these capacitors parts are alway bulges up or puffing up onto it tops.U have all the tools and know basic electronic also can do basic soldering work too?Yes,replaced all these dying capacitors parts are bulges or puffing up on to it tops capacitors parts with the same Micro Ferit and those capacitors voltages like 5 or 10 voltages higher the old capacitors components parts u replacing,now will solved this problems,also capacitors will last longer and have more heat resistance than before.If the tv power supply board check out and have none dying capacitors components parts that are dying and soon to be dead are bulging or puffing up on to it tops.Than the tv have those 2 long boards each of it sides that are called LCD inverter boards are dead,these 2 long LCD inverter boards only job are to provided the tv LCD screen panel a backlight to produced pictures.If u can't repair the power supply board by ur self,if the tv power supply require it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refrubish power supply board or those 2 long LCD inverter boards for the replacement.
Jul 19, 2011 | JVC LT-42X579 42 in. LCD TV
My tv goes click click click and keeps clicking when i turn it on. I have no picture or sound
In most cases it is the capacitors in he power supply section that have gone out.
Common symtoms are
-shuts down
-takes a long time to come on
-relay clicks
-dead set
You can get capacitors online or you can get a complete kit with instructions and support from www.TvRepairKits.com . Its a failry easy DIY fix.
Dec 13, 2010 | Samsung LN46A650 46 in. LCD HDTV
Samsung TV...Turn on tv, it operates for maybe a minute, then shuts itself off and has a consistant clicking pattern, like a relay switch. Sometimes turns itself back on
Not knowing the specific model for your Samsung TV and how old it is, I can only offer this possibility because I've encountered what sounds like the same problem. Certain models of Samsung HDTVs around 3-4 years back have a design problem with their power supplies - they put in the wrong size capacitors (aka "Caps"). After a few years, the capacitors fail, and the power supply also fails. I think it's possible to replace individual capacitors, but most likely you will have to replace the power supply. Unfortunately if it's out of warranty, it will cost several hundred dollars, especially for a home / onsite visit. There is a visible symptom - from 2-6 capacitors on the power supply board will bulge out, as shown in this pic:digizen.jpg
You might try calling Samsung customer service and tell them you are aware of problems with their power supply design, and try to get them to repair the TV for free, especially if you are just out of warranty.
Nov 04, 2010 | Samsung Televison & Video
3 minutes after turn-on, picture gets scrambled
It could be the transformer on its way out on the power board, unplug the tv and take the back of, Trace the the power cord to the transfomer which will be a big square componant, take care not to touch any capacitors, they could still be charged, and have a look for any dark marks on it and check for a burning smell. It'll need to be changed if you do.
Also have a look at the capacitors andand check to see if you can see any signs of leakage or slightly dommed tops, the capacitors should be completly flat at the top. They'll need to be changed if there are any.
Also there is normally a small fuse on the power board somwhere, have a look around and you should find it, it might be worth swapping it out.
Jan 24, 2010 | Televison & Video
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
Click noise...now picture is barely visible
A click means the power to the LCD has been shut off. Try resetting the TV, pull the AC plug, wait a minute then replug.
Jun 13, 2008 | LG 50PC1DR 50 in. Plasma HDTV
Samsung HP-T4254 42 in. Plasma Television Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
