FixYa.com
Tags:
Mitsubishi VS-50605 50 in. Rear Projection Television
Mitsubishi VS 5041 rear projection
posted by dieselprocan on Jun 16, 2008
i have this TV that i simply adore. There is asentimental value attached to it. the problem i have is, it stopped working about 4 years ago, as it lost a RED crt. I am also a survivor from constant nagging from my wife to dump it. i would really appreciate if you can let me know where to find a used crt.
regards
AV
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 16, 2008
Thanks for Trying (70)
techman
Rank:Guru Guru
Rating: 87%, 6632 votes
if it has been four years since the set has worked you are going to ned all three CRT's I'm afraid, the tubes will go soft just from sitting and not being used. also I bet there are a ton of bad capacitors in this Tv set now also.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
Mitsubishi VS-50605 50 in. Rear Projection...
Picture going black
My tv has started going to a... Answer This...
Repair help
My Mitsubishi VS-50605... Answer This...
mitusbishi vs 5041
we moved the tv before the move... Answer This...
VS-5061 -- BLACK SCREEN
While watching TV last night... Answer This...
Constant horizontal lines
Horizontal lines running... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
