Question about LG Refrigerators
I have an LG Elctrnc GRL207EQ fridge freezer and i am trying to find out it's capacity and wether or not it has a double thermostat? Many thanks
dididsaythat
  • 291 Answers
SOURCE: fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Posted on Oct 25, 2007
SOURCE: how to set the thermostat? gaggenau fridge freezer
how to set thermostat on double door fridge freezer
Posted on Dec 09, 2008
davidpsr
  • 222 Answers
SOURCE: fridge & freezer have both lost cooling
How old is the unit? Did the problem start gradually or suddenly?
You'd be surprised what a negative effect dirty condenser coils can have on a refrigerant system. Try cleaning the coils on the bottom of the refrigerator and make sure the little fan that draws air across the bottom coils is running.
Loss of refrigerant can also cause inefficient cooling, but a refrigerator does not 'use' up freon and leaks are rare. If it's losing refrigerant, it's got a leak. But far more frequent are the problems noted above.
Posted on Aug 21, 2009
carputers
  • 255 Answers
SOURCE: lg ICEBEAM GRS512GC. Freezer cooling but fridge
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Posted on Sep 24, 2009
  • 118 Answers
SOURCE: LG FRIDGE,, fan not working or is thermostat faulty?
fan bad or not defrosting look for ice build up behind panel by fan
Posted on Oct 26, 2009
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...---/Refrigerator-freezer-is-cold-b...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...-/LG-Refrigerator-freezer-is-cold-...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
www.bestfridgereview.com/freezer-is-cold-but-fridge-is-warm
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Jan 04, 2016 | LG LFC20770ST
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
I have a LG fridge double door top freezer model no GL-T262QM. the refrigeration compartment is not cooling.
ihave a lg.double door refri model T262QM about 7 years old. no cooing in freezer so i want to get cooling coil capaliry data i am technician
Mar 21, 2011 | LG LRTN22314 Top Freezer Refrigerator
Hi there, Just wondering if you can help fix our fridge - LG model no: GM-589VW, total capacity 589 ltrs. The freezer has stopped working completely (its been a week now) and the refrigerator is not...
The defrosting heating element may have burnt out, if so there should be ice build up in he freezer and would cause poor cooling performance in the fridge side.
Please rate my response.
Jan 15, 2011 | LG Bottom Freezer Refrigerator w/...
My freezer is working but not at top notch capacity. The refrigerator is definitely not working properly as the spring water, for example, is not chilled. What must I do to resolve this...
Hi Alexandra. Hey New York? Brrrrr.
The thermostat actually controls the freezer side. The fridge side is controlled with cold air blown from the freezer side. The controls in the top of the fridge box contain the thermostat/switch, and the damper adjustment for the cold airflow from the freezer to the fridge side. Your problem is a blockage of the cold airflow from the freezer to the fridge side.
1. Frost blockage of the passage
2. Fan stoppage on the freezer side
3. stuck or broken damper
Some dampers are just simple movable plastic doors, some are servo/solenoid/motor operated.
Look up your fridge on Sears Parts, and the exploded diagram will help where to find the passage and how it can be blocked.
Jan 08, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
Faulty Freezer & Fridge
You have a defrost or temperature control issue or both. I will be back soon with photos and solutions. Thanks, Sea Breeze
Jul 13, 2009 | LG LRTBC1825T Top Freezer Refrigerator
How to set the thermostat? gaggenau fridge freezer
Nov 24, 2008 | Gaggenau Refrigerators
Refrigerators Logo
67 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
