Question about HP Mini 1000 Netbook
When i turn on my note book, all i see is a red screen with the compaq label in the middle of the screen. at the bottom left is a message ' press the ESC key for startup menu'. when i try to restore it using the xp cd, i get a blue screen error, telling me to remove any newly installed hard drives or hard drive controllers. to check my hard drive to make sure it is properly configured and terminated. run CHKDSK/F to check for hard drive corruption and then restart the computer.
    Scholar:
  • 77 Answers
This issue might be due to system file corrupted.
You will face this issue again if this restore successfull.
You can fix this issue by reinstalling the OS(Windows XP)
Formating the C drive and reinstalling the XP will resolve this issue permanently.
Posted on Nov 08, 2010
How do i reset the answering machine on my cordless phones at home
My panasonic handsets have a row of black buttons above the number keys and answer and end call buttons. The screen above these shows little pictographs of what the buttons will do, the left has a book which is the phone numbers stored on the hand set, the middle one has a picture of 2 rows of 3 white dots, this is the button to press once. You then get options of Caller list, Answer system, Handset setup and Base unit set up. Use the big central button with arrows to scroll through the list, please note that the base unit is off screen initially. Select Answer system by pressing the black button below ok. This givs a new list of options, Play new message, play all messages, Record Greating, Answer on, Answer off, PLay greating, Erase message and settings. Slect the required option by pressing black button below the on screen OK. The left hand button will take you back a step, but if you don't press anything after a short time hand set returns to normal. Hope this helps
Sep 06, 2016 | Panasonic Lands Phones
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
-1985 Porsche 911 took off door panels pulled the wires off the power window switches did not label them and now i don't know what color goes to what # connector on the switch
hello there
As you are looking at the switch ,the single connector should be on the top.
Top single conn. is linked with bottom left(red wire)
Bottom right -brown
middle left is blue with black strip
middle right blue with white stripe.
Sometimes this middle wires should be switched(left-right position), the are for window doing up and down.
Same goes for the front switch for pass window.
i hope this helps
Ivan
trubka
Nov 29, 2010 | Porsche 911 Cars & Trucks
Its turning to german and how to fix it
If you mean the DS language is in German, then power on the DS without a game card inserted.
Touch the screen to continue.At the bottom-middle of the touch screen, touch the little DS icon, under the 'Es befindet sich kein Modul im Modulschacht' (There is no Game Pack inserted) message.
At the next screen, touch the Spanner (1st from left) icon. Touch the Globe icon (middle-left). Select 'English' presumably (top-left), or what ever language you want. touch 'A Bestätigen' (bottom right) or press the A button. At the next screen, touch 'B Go back' or press the B button, At the next screen touch 'B Quit' or Press the B button. Touch 'A Yes' or press the A button.
If you mean that a game is in German, then check within the settings of the game, generally you should look for a Globe type symbol, this should give you a menu to select a language from, or look for text such as 'Sprache auswählen'
I hope this is of some help, if not can you be a little bit more specific
May 08, 2010 | Nintendo DS Lite Console
Why wont red Message light on my Nortel Phone
more than likely someone in your office left the message rather than the voice mail. to clear it press the call soft key below the screen. the screen should display who left the message with two of the soft keys labeled call and erase. press the erase soft key. it's possible the the person/s that left the message left multiple messages. in that case repeat the procedure til all messages are canceled
Jan 13, 2010 | Nortel T7316E 2-Line Corded Phone
Compaq presario
Right-click your desktop and go to Properties (Note: Don't click an icon, just the background image of your desktop). Afterward, click the tab at the top of the new window labeled, "Screen Saver." Now at the bottom of the Window select, "Power." Now change the settings so that the system doesn't turn off the hard disks, enter standby mode, or hibernate. Afterward press OK, then Apply, then OK again.
Let me know if I can help you further, or if I need to describe any of the above instructions in more detail.
Mar 22, 2009 | HP Compaq Presario SR5610F Desktop PC
Speaker phone
Hi.
When u place a call, look at the screen ( bottom middle) and when the little phone icon shows up, press your ok/i button(the silver button in the middle) to activate it. Alternatively, if someone calls u, when u pick the call up, on left side bottom of screen it says option, select speakerphone.
Feb 04, 2008 | Samsung SGH-D900 Cellular Phone
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Green and red color problem on bottom left to a little past the middle of the bottom of screen
the convergence ic's are breaking down and require replacement should cost under $ 250 depending on your service shop.
Nov 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Bang and olufsen BEOTALK 1200
Make sure answer machine function is turned on. Bottom right button.
Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
Aug 28, 2007 | Bang and Olufsen Beotalk 1200 Digital...
HP Mini 1000 Netbook Logo
112 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
