Question about Sony PlayStation 2 (PS2) Console
Took it apart like ive done many times before
This time i disconnected the silver tape/wire don't know where it goes. am i screwed?
  • 65 Answers
No you are not screwed.
You can find a lot tutorial on line how to tear apart your machine.
Actually i need to know what cable you removed or how look like .Usually the only 2 cable i do know if you replace your laser are...1 the connection between the motherboard and the laser(that cable is brass color) and the other one is the one for the ON/OFF button
Posted on Jun 18, 2008
Electricity-conducting tape on TV circuit board?
the silver strip is a ground lead,the tv will work fine without it..just make sure the ground screw are tied
Oct 06, 2017 | Televison & Video
Took my Pioneer CT=1040W apart. Main belts for both dual tape decks were melted onto the pulleys. There is also another belt on the B tape deck. Appears to be intact, but can't see where it goes.
The repair of a dual cassette deck is usually not worth it if you are paying a Technician but since you are doing it yourself, there are screws that must come out of the deck to take the transport out. Some of them require you to take the plastic door off. They are not a treat to work on and often even when you are done they have poor performance anyway. Where the belt goes is indicated on the pictorial diagrams of the service manual. Otherwise it is common sense and a little bit of physics. I have probably done 400 by now. Maybe some TV shops will work on it but they are really not real Technicians for tape decks and most times hacks.
Dec 27, 2016 | Pioneer Audio Players & Recorders
Electrical outlet help
Not sure either without more information. Good video, but where exactly were each wires on old device?
Did red go into back of old device on black side or white side?
Black side of wiring device should have brass screws and white side has silver screws.
Use a tester. Tape tester leads to wood sticks. Turn power ON and test each black wire individually to each other wire. When tester lights up, that black wire is Hot wire. And the white wire it lights up on is Neutral. Black will connect to Brass screw on new outlet, and white goes on opposite side on silver screw.
Then add other wires one at a time in process of elimination.
Add a comment.
Aug 19, 2013 | Electrical Supplies
Manual for black and decker circular saws #7301 type A
Okay im restoreing an old Black&Decker circular saw 7 1/4 volt 120ac Amps 9.0 Type A Rpm 4900 now im putting it back togather and i need help Ive got evrything else down patt just what the saw blade sets on there's like a lil motor that is togather where the blade goes and has teeth all around it and connects to the big motor it has a pin there ive found that just when i put it all togather there's a gap there and dont know why ive took my time and went from one screw to next easy and still does the same thing i thought maybe something was in the way where the two plates screw down but there is nothing in the way any idea's help me please
Jan 12, 2012 | Black & Decker Saws
How do I remove the shredder head case of an Aurora AS890C? I have removed the 6 screws (it's unplugged), but it still won't come apart. It quit working, so I don't know if it's jammed or...
There are 7 screws. You missed the one hidden under the small silver label.
Once you take it apart, don't waste your time calling Aurora as you voided your warranty and ability to get help from them. That happened to me.
May 12, 2011 | Aurora Electronics AS890C Shredder
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
How do you take apart an HP w1907 monitor? I have one that the picture only stays on for a split second at power up and then goes blank. I suspect a filter capacitor but can't take it apart to check.
haha, been there. This ones a little tricky. Hope you have strong fingers. start by removing the base. There are 3 screws. First pull the base plate off. Then remove 2 screws. Next remove the little rubber insert in the center of the base bracket. You will need a long phillips to get to the 3rd screw. Slide out the base bracket. Flip the panel over and stare at the lcd with the buttons side on the top. Grab a small flat head screw driver. Look at an angle in each of the corners between the inner black lcd trim and the silver outside trim. There is a ****. Shove the flathead in there and pry outward toward the silver trim while lifting on the black inner trim vertically. The trick is to flex the black trim toward the silver and then pull up. There are 6 plastic snaps on the top and bottom, and 4 snaps on the left and right. If you've taken laptop screens apart, you'll feel the similarity.
Once you pry the black trim off the front. Disconnect the LCD Menu button assembly and power button. Then flip over the LCD and lift off the back shell. Looking at the back, remove the 2 connectors for the speakers. Use a small flathead to pry the 4 Inverter power connectors. These 4 connectors have a clip on them and are usually hard to pull out using the wire. Once thoses 6 connectors are removed, remove the 2 phillips screws holding the AC power plug to the case. Also remove the 4 3/16 posts for the VGA and DVI ports. Next remove 4 screws, 2 screws from each side of the LCD assembly. Hold the panel face down with the aluminum tape in the bottom left. Lift the shield and guide the 6 wires through the cage. While opening, look inside and disconnect the flat ribbon cable as soon as you can. Put the LCD to the side. Remove 2 screws from the Video processing board, and 5 screws from the power supply. Note: 1 of the 5 screws is longer. Rotate/slide the power PCB away from the cage to clear the speaker and AC plug, Then rotate towards the Video board. Disaconnect 1 plug. The OTHER plug is SOLDERED and must be disconnected from the video processing board.
There you have it. It stumped me for about a half hour. No pry marks. Barely noticed the 2 slits in between the trims. Well, good luck. Happy Soldering.
PS: I opened mine because I assumed it had bad capacitors. It only powers on for a short short period of time.
Nov 17, 2009 | HP f2105 21" LCD Monitor
How to wire combo switch
you should have 4 wires total (not including grounds, which get twisted together and connected to green screw) you have to know which is the power lead, and which goes to the light! 2 blacks, and 2 whites ...the 2 whites go together and connects to the silver screw, and the 1 black power lead goes to the gold screw, the other black wire(to the light) goes on the opposite side of switch above the silver screws on another gold screw
Apr 06, 2009 | Leviton Combo Switch Receptacle - 5225-T -...
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Sony PlayStation 2 (PS2) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
