Question about Whirlpool Kitchen Ranges
Whirlpool stove smooth top model GJP84802 bottom burner does not work.(top ones OK) How do you replace the bottom burner.
5 Suggested Answers
Amigaman
  • 248 Answers
SOURCE: Whirlpool electric range top burners
Probably have to replace the infinite switches. These are the controls you turn for the burners.
Posted on Nov 18, 2007
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
SOURCE: Whirlpool electric stove
My sister has a whirlpool electric ceramic top stove/accubake sistem....the problem is that my husband took the door of the oven off to clean and now he can't get it back on......where on vacation at her house and want to fix it before we leave sept. 30/08. We need help fast.
thank you
Posted on Sep 28, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
How do I change a burner on a smooth top stove?
usually the top will tilt back so you can get to the elements .
Apr 09, 2016 | Kenmore Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
My whirlpool electric stove a burner don't work l
my whirlpool electric stove top two big buner is not working
Nov 28, 2012 | Kitchen Ranges
I have a whirlpool stove - smooth top and one of the burners will not turn off - what can I do
Hello, Thank You for using FixYa. I will be helping you today.You will have to replace the infinite switch the switch you turn to turn that burner on and off. This should fix your issue.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Whirlpool Kitchen Ranges
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
Surface burner on electric smooth top range not heating. When turned on, the left rear burner does not light up at the dial or on the surface. How can we determine if replacement is necessary or there is a...
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
Jan 24, 2010 | Kenmore Kitchen Ranges
The cooktop indicator light is still on even when all the knobs are in the Off position on my Whirlpool range model RF265LXTY
MOST SMOOTH TOP ELECTRIC STOVES THE INDICATOR LIGHT WILL STAY ON UNTIL THE BURNER COOLS OFF.IF THE BURNER IS COOLED THEN ONE OF YOUR SURFACE BURNER SWITCHES IS BAD AND WILL NEED REPLACEMENT .HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Whirlpool RF265LXT Range
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
80 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
