Question about HP Deskjet 3845 InkJet Printer
Blinking power light
I have a HP Deskjet 3845 printer and I have recently changed the black ink catridge. It was working fine a couple days ago, until today when the power light started blinking. It won't print at all and it says something is wrong with my right catridge, so i take that out and it says something is wrong with my left catridge. But i didn't even touch the colour catridge at all!
Any help is greatly appreciated.
  • 4 more comments
  • kaliee Jun 16, 2008
    the printer starts up as if i just turned on the power, but it continues blinking
    you mean i have to get a technician to fix this? No way I can fix it myself?
    sigh.. sucks how it was working fine just this morning!
  • fwt07echo Jun 23, 2008
    The power light(on left) blinks continuously. I removed paper and reinstalled--still won't print. It has not been used for months before.
  • sat_san Jul 09, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to kaliee's Blinking power light problem, and notify you when a new solution is offered.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What happens when you put the cartridges back in, unplug the printer from the electical outlet, wiat 10 seconds, and plug it back in?
  • Tim Babcock
    Sergeant:
  • 174 Answers
You remove both cartridge and clean the electrical contact points at
cartridge and printer and try.
Posted on Jul 23, 2012
  • HP Master
  • 2,794 Answers
It could be the timing of the cartridge is out possibly from the belt.
It should be serviced by a technician.
Posted on Jun 16, 2008
  • Tim Babcock
    Tim Babcock Jun 16, 2008
    It could be the motor or the timing is off. Unless you had a paper jam happen today, there might be some paper in the path or blocking a sensor.
How do i print a self test for black ink through Linux Ubuntu for a hp deskjet 3845.
Open the Printer widget. Select your printer option for a a self test. But I believe that a self test option should be available from the printer's own command panel.
Oct 08, 2014 | HP Deskjet 3845 InkJet Printer
I have an HP Deskjet 3845 printer and the power light is blinking. It also says it is offline. I have deleted the printer and re-installed it and I have also unplugged it but it is still blinking and...
It could be because the Ink cartridge is defective , Did you try removing one cartridge and restrat it to see if the blinking stop , if not put the cartridge back and pull out the other one and try again !
Jul 31, 2011 | HP Deskjet 3845 InkJet Printer
Hi there, I have recently changed the black ink cartridge in my HP Deskjet 3845 printer, but it now prints with purple ink. Can you help?
have you cleaned the print head? done a test page? i had a simlilar problem with a lexmark but it turned out to be a refilled cartridge. if you are using genuine hp cartridges i would recommend printing a test page and checking the solid colours .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=372330
hope this helps!
Jan 19, 2010 | HP Deskjet 3845 InkJet Printer
HP Deskjet 9800
push the printhead in a wet towel
until you can see a clear print Imprint
on the wet towel
Mar 23, 2009 | HP DeskJet 9800 InkJet Printer
Blinking green light
Clear the paper jam, or replace the ink cartridge. Possible causes are the paper jam or ink cartridge. The other solution is to disconnect the power from your printer and reconnect it. Hope this helps!
Oct 22, 2008 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 Printer
Try uninstalling both printers and their software and then reinstall them, the 3845 first. See if you get the same results before installing the 2610.
Oct 16, 2008 | HP Deskjet 3845 InkJet Printer
HP DESKJET 1280
I have the same problem. Yellow light now constant and will not print at all.
Oct 11, 2008 | HP DeskJet 1280 InkJet Printer
My HP printer's light blinks, but it doesn't print.
two things to consider.
1. If the blinking is fast (like more than two blinks per second) then the printer is damaged. Either the main controller board is fried or the carriage/ink controller is damaged.
2. if the blinking is slow ( 1 blink per second) this means that either of your cartridges is busted. remove the black cartridge then close the top cover. If the blinking stops, then the black ink is the culprit. If not, replace the black then remove the other cartridge. THis means that one of your cartridge needs to be replaced.
Sep 27, 2008 | HP DeskJet 3940 InkJet Photo Printer
Hp deskjet 1280 black colour problem
remove the Printer Catridge & clean the belw points where the INK come out, & shake properly & insert,
May be catridge ink got dried,
kiran
Jul 29, 2008 | HP DeskJet 1280 InkJet Printer
HP Deskjet 3845 InkJet Printer Logo
383 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
