Question about Stoves Heating & Cooling
Instructions to hook up peerless bucket a day coal stove
I am looking for a manual for an Atlanta Stove Works Homesteader Model 340ADG wood/coal stove that has been installed in a house I just moved into but has never been used.
Hello John,
Here is a manual for your stove, you can also call the phone number # 340ADG Here's a bit of history about your stove; Atlanta Stove Works there's even a PDF about a slightly different stove on this site.
Good Luck!
Rich Lilja
Jan 10, 2017 | Home
What is a coal scuttle
its a bucket you put coal in and the leave it at the side of your fire place.
Dec 09, 2016 | Grilling
I need instructions for placing ceramic coals on a Cannon inset gas fire 26730G
Go to the wed site I Think stoves own cannon you should be able to your make of fire and down load a manual show how to replace your coals
Dec 06, 2016 | Heating & Cooling
Burner adjust on Peerless gas stove
WELL THIS SITE REALLY HELPED ME THANKS FOR ALL THE ADVICE
Nov 30, 2013 | Kitchen Ranges
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
How do I use the stove. We bought a house with a anthrasite stove, but we do not have an idea how to start it
Not sure which model you have, Reading Stove Co makes the anthracite model. Here's a link to their website http://www.readingstove.com/ Click on the Coal Stove Safety Tips tab and look for your model under Owners Manuals.
I hope all of this will be helpful to you.
Mar 11, 2011 | Heating & Cooling
My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
Oct 31, 2010 | Ovens
Instruction manuals
http://www.peerless-faucet.com/customersupport/requestliterature.html
Click on the link above and you can request the literature you are requesting. Peerless is made by Delta.
Mar 18, 2009 | Peerless Industries Peerless& Single...
Heating & Cooling Logo
171 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
ghold1
Level 1 Expert
vance jones
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
