Question about TORK Hardware & Accessories
I need a programing book for a Tork SS720A in wall switch
How do i program a tork dtu40 timer
1) Copy following link for programming manual and wiring Tork DTU40 40amp timer.
http://waterheatertimer.org/How-to-wire-Tork-DTU40-timer.html
2) The timer mechanism is old Intermatic/Grasslin/GE discontinued model, and then newly re-minted by Tork in 2012. Timer has 1 year limited warranty against defects in workmanship. This timer is protected from surge by the reset feature, but can burn out in heavy surge event. Non-replaceable Internal rechargeable battery retains programming until timer is reset. Always reset new timer to delete trace memories.
3) This timer can be wired many different ways, and timer automatically detects voltage, so there are no dip switches to set. Timer must be wired before power is turned on. Do not spark-test across terminals.
Feb 17, 2013 | TORK Hardware & Accessories
No display stop working. it controls a fan lite, the lite is on in a dimmed mode, no fan function.
Question posted under Tork SS720 timer.
I don't have repair for defective timer that worked before and stopped working.
If this is new timer, then add a comment and explain wiring in exact detail, and include what you mean by 'dimmed' mode.
Timers have 1 year limited warranty.
Timers are affected by line noise, and generally cannot be connected to a dimmer.
SS720A timer is robust 120Volt single-pole 7-day programmable timer, rated for 15Amp up to 1 HP.
The larger the amp load, the shorter the lifespan for electrical devices.
Last step troubleshoot for programmable timer is to reset timer and reprogram.
Reset timer by pushing in reset button for several seconds.
If functionality is not restored, then timer has gone bad.
Tork SS720 is identical to GE15071 timer sold at Home Depot.
Buy another timer, and return defect in new package.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/pdf/SS720A-Tork-In-wall-manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Aug 19, 2011 | TORK SS720A 7 Day In Wall Digital Timer
I need instructions on how to set the timers on my tork electric timer for my outdoor lights ,it is put into my switch inside
Here is link to Tork in-home timers showing digital 7-day programmable timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#SS700
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Nov 06, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How to set a tork timer?
Tork makes a page-full of timers.
Rotate dial until current time lines up with arrow, then set the pins as shown in photo below
1) If timer plugs into wall receptacle, it has pins around the dial.
2) If timer replaced a wall switch it also has pins around dial.
GE and Woods and Tork and Intermatic each make similar timers.
Pull and push the pins to set times.
The wall-switch type timer also has a switch >>> move switch to Timer
Up-vote if this information helped. Thanks for the feedback.
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
Lost programming instructions, need help to reset or copy of programming manuel
Go to tork.com/tork/residentialtimers.aspx and you will see your model and then click on it for your wiring diagram
Oct 01, 2010 | TORK SS720A 7 Day In Wall Digital Timer
HOW DO I INSTALL A TORK SS720A TO A THREE WAY SWITCH
The Tork SS720A's can only be used to replace a single pole switch. For 3-way switches you need the Tork SS700 or similar device like any of the SS700Z series.
http://www.electriciansupplies.com/product.cfm/p/123028/Tork-SS700.htm
Mar 02, 2010 | TORK Hardware & Accessories
Need the tork spec for the rods, mains, and cam 99 cav 2.2
go to any good parts store and get or order
a repair book specific for your car that
will have the info that u require
gl G
May 03, 2009 | 1999 Chevrolet Cavalier
Hardware & Accessories Logo
120 people viewed this question
Top TORK Hardware & Accessories Experts
 Kenneth
Kenneth
rgbypoet
Andrew Taylor
Andrew Taylor
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
