Question about Fellowes Powershred 420 Shredder
Powershred 380-c Shredder keeps stopping with the red trash symbol showing - which normally appears if bag is full or shredder is jammed. Even if I empty the bag and clear the shredding 'teeth' the same thing occurs - occasionally it'll allow a couple of sheets to shred - but will stop again soon after. Help!
  • Anonymous Mar 25, 2009
    I have oiled the shredder once a week and cleaned the teeth - removed the shredded material and the red trash bin light still lights up. I can override it but not happy that this has occured so soon after purchase. We are not heavy users either. This is a Fellowes C380-C.
    Sergeant:
  • 329 Answers
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Posted on Jun 24, 2008
Thanks for the possible solution!
I had been looking after it by regularly clearing out the shredding teeth and oiling it but the issue kept kept reoccurring.
I ended up taking the shredder to a local service company and they ended up replacing the LCD PCB. Now it's working fine!
Thanks
How can I buy a replacement guard strip?
I do not know it you can or not. Below is a link to the manual; look for your model and down load it. It might be of some help to you, Good Luck.
Fellowes Shredder Manuals
Oct 08, 2014 | Fellowes Products - Powershred Shredder...
What size bags fit the PRIMO 3900 HS Level 6?
You could measure the frame of the shredder (add about 7 inches in height for fold over) and convert to gallons. (Most bags are rated in gallons.
Looking on the Primo website, their current model, the 3901 shows it to be 148 liter (approximately 39 gal).
Primo 3901
Their bag number for this machine is part number 1.235.997.403.
(Here's a manual for a 3901, don't know how closely it will match the 3900):
http://www.primo-office.com/fileadmin/Downloads/Betriebsanleitung_Aktenvernichter/Primo/3901/Primo_3901_T1.pdf
You could call them at 800-613-2110 (but I imagine you will pay through the nose).
Staples sells a 38 gal bags designed for the Fellowes Powershred, number 3605801, $60 for 50 bags ($1.20 ea). They measure 23"x23"x21". Measure the frame and see if these fit. (Again, allow 7-8" for overlap at the top).
Fellowes Powershred Shredder Waste Bags 3605801 Make More Happen at...
or-
http://www.staples.com/Fellowes-Powershred-Shredder-Waste-Bags-3605801/product_703101#desc_content
HSM sells 100 bags for $98 ($0.98 ea), designed to fit the HSM 390.3 Level 6 shredder (think it's similar to the Primo 3900 at 39 gallons).
HIGH SECURITY SHREDDERS
Aug 26, 2014 | Office Equipment & Supplies
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
Hi my shedder PS -60 has the red light on but nothing is jammed - can you help?
I don't have your shredder, but check to see if the top part where the shredder mechanism is closes completely over the trash can. If it is not lining up, it may have a shut off switch. I had put a plastic bag inside mine to catch the bits, and it bunched up at the part where that connection needs to be clear and it stopped. When I smoothed that area, or removed that bad, it worked again. GOOD LUCK!
Jul 24, 2014 | Fellowes Powershred PS-60 Shredder
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Shredder stopped working lights come on shredder doersn't not jammed
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Apr 21, 2014 | Fellowes Powershred PS-60 Shredder
Shredder keeps stopping and the bag is not full
there are three switches on most shredders that can cause them to stop.
1) a jam
2) door ajar
3) bag full
If you can rule out a jam, and the door ajar light goes on when the door is open and off when its closed, and the shredder has not been undergoing very heavy use (they will overheat and shut off, then be fine in 15 min or so)
then its a safe bet to say that it has to do with the switch that tells the shredder that the bag is full (when you take out the bag you can see a metal flap hanging down at the back of the top opening)
the way that the shreddings fall can often trip the swtich that tells the shredder that the bag is full, shake the bag a bit so the paper resettles that often fixes it.
Nov 08, 2011 | Fellowes Office Equipment & Supplies
The red light is on and it will only shred backwards. what does that mean?
it means you have a jam. check below the shredder heads for paper hanging down triggering the jam sensor. to check this, open the front door, remove the waist basket or bag, then look up underneath. Make sure it is turned off and unplugged so there is no chance of an accident.
If you see paper hanging down, remove the paper, and try it.
hope this helps!
Ryan
Nov 02, 2010 | Fellowes Powershred 480 Shredder
Won't shred
you have to replace the main power switch
Mar 31, 2009 | Fellowes Manufacturing FEL36055 Powershred...
GBC Quartet Shredder - Service manual
try this customer service number for help 800-541-0094. I believe that Acco is the parent company for GBC.
May 09, 2007 | Quartet gbc 3270M Shredder
Fellowes Powershred 420 Shredder Logo
603 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
