A problem about printing the printer needs tobe reset? any software i can use to reset my printer
Will not print black & white. color only
You need to reset the B&W and the coIour cartridges and then reset the printer. Often the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Check the leads from the mother board and also the contacts of the ink cartridge , if jammed or tight remove and manually free the drive before it is set back.
Thank you for using FIxya
Sep 05, 2011 | Dell V313w AllInOne InkJet Printer
How to reset epson T13?
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME . INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF. INK LEVEL LEVEL ALWAYS SHOW 100 % NO WASTE INK PAD COUNTER MORE NO NEED TO WORRY WHILE PRINTING MORE PRINT JOBS now no more ink cartiledge not recognise problem
Mar 24, 2011 | Epson Printer
Printer wont print. in the printer folder. It says outbind://d228e32b65a8ea469e30712202a875730644b2300
Try to have a reset .Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command .If the reset wont help it can be the printing head or a mother board error.
Sep 30, 2010 | HP OfficeJet 4315 All-In-One InkJet...
I purchased sumsung ml1640 printer catraige newly fill up after printing not came became a error came toner exhausted. please solution me.
it is very simple but need some electronic soldering knowledge. simply solder a piece of wire as in this picture. your printer never say "toner exhausted"
Sep 01, 2010 | Samsung SCX-4300 Monochrome Laser...
Replaced ink in 2200 and says need new ink still will not let me
I guess your printer need to reset the counter ink pad, for reset the counter you must have a adjustment/reseter software, and for your printer type please download <a href="http://www.ziddu.com/downloadlink/7587521/sscserve4.3.exe">here</a>
I hope this link can solve your problem
Dec 21, 2009 | Epson Stylus 2200 InkJet Photo Printer
How to reset my printer canon ip 1880.thanks
If you ask for reset of ink levels you can't.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.The printer shows empty cartridges but it will printing.
If you ask for waste ink tank reset follow this:
  1. Press power button while plug in the power cord – green lamp.
  2. While hold the power button press resume button twice – orange blink and return to green.
  3. Release the power button, Then the PC will recognize new printer install.
  4. You need the software for permanent reset.
  5. Run the software and select printer port.
  6. Then select Set Destination
  7. Click MAIN and PLATEN button to reset waste ink counter to zero.
  8. Finally test print by click TEST PATTERN button.
Oct 19, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
6 orange and 1 green flashing light on S400 canon bubblejet
Friend your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
Apr 09, 2009 | Office Equipment & Supplies
Not Printing. Reinstalled the software, reset printer to factory
If you are running Leopard, reset the printing system by control-clicking in the list of printers in the Print & Fax preference window. Then reinstall the drivers.
Apple Menu > System Preferences > Print & Fax. Control Click in the left area which shows the list of printers, and choose "reset the printing system"
macs2u
Apr 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Samsung SCX-4216F - loud banging noise
the doctor blade in the cartridge tobe replaced.
Jun 18, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
