I bought a new FL36R flash. Attach to hotshoe,turn on camera,turn on flash,press mode button repeatedly to get TTL auto mode. But the firing range and the focal length not displayed and the flash won't fire
Set camera to ASA/ISO 400, set in P, set lens in A.
Park flash on hotshoe.
Press White Button and wait until Pilot turns Green.
Press Set Button then to move those Arrow until it covered TTL(White on Blue).
Turn on camera.
Enjoy shooting.
What camera that you are having problem with those flashes?
Will switching the two have the same problems.
Make sure it is fully pushed forward into hotshoe & locked:-)
Try shooting second current, this will save you the repair costs.
Your exposure compensation was set to zero, but was your flash compensation set at zero?
Does the pilot lamp light up? If so can you fire it manually by pressing on it? If the batteries are low it may simply just be taking a while to charge, the camera will not wait for it to be ready to fire and it may seem to be not working. If your flash can be fired manually however, there may be a problem with the cameras shutter or the hotshoe. You can do a basic check by pressing the star button at the rear of the camera, you should get a pre-flash. If not, there is a problem with the cameras hotshoe which you will need addressed by a service centre. If you get a preflash you can next check the cameras shutter by setting the second curtain to sync with the flash. This can be done via the cameras "Custom Function" menu, c-Fn 15. Set the camera to TV mode and chose a 1 second exposure. Take a shot with the flash attached, if the shutter is working correctly, the flash should fire a pre-flash and then a main flash. If it doesnt, the switch inside the shutter is broken and the shutter needs to be replaced. This is a pretty labour intensive repair and you may consider an upgrade as more economical.
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash 2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens 3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S 4) Range-priority manual flash; available with SB-800
Flash Control
Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
Make sure both camera and flash are set to TTL automatic mode. One time this happened to me and I had forgotten to lock the flash to the hotshoe connector.
If you are using Pocket wizard you attach a hotshoe to pocket wizard adapter to the unit that usually fits on your camera hotshoe and attach this unit as usual to the 76mz5. There are various brackets that can secure and tidy the whole thing but you can manage without them if you wish. I got the paramount hotshoe to pocket wizard mini jack to do this £35 each from TFC and the bracket to fit the 76 MZ5 to a stroboframe bracket from speedgraphics at £17 and a one to fit the TTL controller to the 76mz 5 keeping it all tidy in all it cost £67 but makes a neet little unit that can be mounted on a stand and if you want to spend another £25 you can even attach a brolly. Great as a studio flash unit
You probably haven't changed the camera and/or flash back to TTL mode from wireless mode. Make sure they are both set to TTL, not commander mode and you should be fine. Note that the LCD on the flash will indicate which mode it is with a little graphic. On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
When you attach the flas to the camera can exidentli fire. This is normal, and manufacturer recomendation, turn off the flas unit before attach or deattach, prevent this fireing. Fireing when you turn the flashead is not normal. Probably the mounting foot of the flash unit can move in the hotshoe, breaking connections between the connector pins, causing exidental fiering. Always lock the locking lever of the flas, wich can prevent this unwanted movement. Also chek the hotshoe on the camera, wich should to have a "leaf spring" keeping the flash unit steady.
