Question about Honeywell Heating & Cooling
Wiring diagram for a honeywell st6400c programer
  • 17 Answers
SOURCE: Honeywell ST6400C with no display
I am not familiar with this particular model but in general all digital thermostats are either powered by batteries or by the 24 volt transformer from the furnace. Usually the standard heat/cool type that you may have is powered by batteries and will show a low battery display for a few days before they go out entirely. You may have missed that warning because of your being away.
There will either be a small door on the front of the thermostat or you will need to pull the thermostat from the subbase and the batteries will be inside. Usually 2 AA size....replace with the good kind.
Good luck
Posted on Nov 14, 2008
  • 17 Answers
SOURCE: replacing Honeywell heating progrmmer
yep the wires will hook up to the same designations, just write down what color was connected where. You will need to set the thermostat up for your particular situation...gas, electric, heat pump, ect. The installation maunel is very clear on this aspect so you should not have a problem.
  • 148 Answers
SOURCE: Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
Posted on May 10, 2009
wcrawf11
  • 52 Answers
SOURCE: I need a user manual for the Honeywell ST6400C
You should be able to get the informatiom you need here. http://ecc.emea.honeywell.com/products/ecatdata/pg_st6000.html
Posted on Dec 12, 2009
SOURCE: User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Posted on May 20, 2011
I have Honeywell st6400c. The heating runs all the time although I have switched off the programmer. I have just replaced the wired thermostat with a remote one. Could the wiring be incorrect
Start from scratch and do t hardest thing there is for any man to do......................STUDY the directions for the new components.
Sometimes it's THAT simple to correct a mistake. don-ohio (:^)
Jan 16, 2017 | Honeywell Heating & Cooling
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
My st6400c Honeywell programmer blank. Mains turned of whole day. Now back on, but st6400c blank.
Have you tried pressing the 'Reset' button (with the tip of a pencil)? After doing this, you will have to re-enter the various times. It could be that your rechargeable battery is nearing the end of its useful life, by the way.
George
Feb 23, 2011 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C
Sep 17, 2009 | Honeywell Electronic Programmable...
May 08, 2009 | Honeywell Programmable Thermostat Heater
No hot water honeywell st6400c
HW valve was stuck in the open posiion and the micro-switch was not working so thats why boiler and pump were not starting. Bled system to below the level of the valve to be changed, and replaced valve with a drayton ( easy quick change of valve head if needed no screws )
Sep 07, 2008 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
582 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
