Question about HP Office Equipment & Supplies
I have 7410 HP all-in-one priter , it's not printing right,printing partially . so i replaced the tri color , now the alignment fails.How should i know that the ink is out or not and the black or tri color?
  • HP Master
  • 7,733 Answers
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
Ink cartridge doesnt any help
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on.Figure 1: Press the On button to turn the product onc00442142.gif1 - On buttoncaution.pngCAUTION:If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One.Figure 2: Open the access doorc00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.Figure 3: The print carriagec00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper positionc00442144.gif1 - Print cartridge slot for the tri-color print cartridge2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Step two: Install the new print cartridgeBack to top
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.Figure 5: Remove the tapec00442146.gif1 - Copper-colored contacts2 - Plastic tape with pink pull tab (must be removed before installing)3 - Ink nozzles under tapecaution.pngCAUTION:Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Insert the print cartridgec00442148.gif
  3. Close the print-carriage access door.Figure 7: Close the access doorc00442149.gif
Step three: Align the print cartridgesThe HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. Use the following steps to align the print cartridges from the control panel.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray, and then press OK .
  2. The HP All-in-One prints a print cartridge alignment sheet.note.pngNOTE:If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  3. Lift the lid. Place the top of the alignment page face down in the left front corner of the scanner glass. Close the lid.Figure 8: Load the alignment sheet on the glassc00443602.gif
  4. Press OK to begin the alignment.
  5. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Oct 28, 2011 | HP Officejet 5610 All-In-One InkJet...
When aligning printer ink --- get alignment failed signal
That is the most common issue on the HP printers.Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
If the problem persist uninstall the printer.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 7140xi comes up with alignment failed after replacing black pr
you could try by passing the alignment
Press and hold Setup and then press OK simultaneously when align message is prompted on the All-in-One.
Jan 27, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
My HP 7410 will not print in color. Black
my hp printer officejet7410 made a wierd noise and now the only color that anything prints is in reds and pinks.
Jul 13, 2009 | HP Office Equipment & Supplies
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
Printer cartrige question
Most hp printers print a alignment page when one of the cartridges is changed. If the other cartridge is empty, alignment fails, and printer will not work...
However for most printers is possible a procedure for bypassing a
alignment... if you tell me which printer you have !
Jan 12, 2008 | Office Equipment & Supplies
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
Seeker5211
Seeker5211
