Question about Nokia N97 Cell Phone
I need the reset code to preform a factory reset
  • 251 Answers
Soft resetting :
-Back to factory settings: This should maintain your data (contacts/messages/calendar/notes etc), just returning your N97 back to all previous settings
From menu:
Settings> Phone>Phone Management>Factory Settings
hard resetting:
The traditional method won't work as the N97 doesn't have the old keypad. After you've backed up your data onto memory card/pc/ovi, turn your phone off and simultaneously press these four buttons circled in red.
  • Caps shift
  • Space bar
  • Delete button
  • On button
You'll know it's worked when you see the initial set up screen, asking country of origin.
Posted on Nov 08, 2010
My daughter bought me a kindle in Christmas 2014. For two days I have had it on charge. It will not open it is locked. I have pressed all knobs but it will not open.
youll need to preform a hard reset to remove the lock if you or daughter doesnt know code.
depends on kindle version.
hold power button in on position for 30-40 sec and let go and restart
or hold power and an android menu will appear
once you get into menu choose wipe cache first and then choose
wipe data/ factory reset and then reboot
this should remove lock
depending on kindle edition their may be a reset hole that needs to be pressed with a paper clip or saftey pin hold reset button for 30-40 sec.
look at second step here
Kindle Fire Reset to Factory Defaults
look at hard reset here
How to Reset Kindle
Nov 10, 2016 | Amazon Kindle
I made it to the screen that I want. Wipe data. Factory reset. What do I do now to preform this
Just except or press ok, I hope you under stand that all data will be removed, so back up if any data needs to be saved.
Sep 27, 2016 | Cell Phones
For the 2001 windstar, after you get the codes. To reset anti theft systems, how do you preform the reset.
What codes did you get ? If there where codes any codes ! You need to have the problem fixed ,that's how you reset the anti-theft system !
Apr 19, 2015 | 2001 Ford Windstar
App store not opening and cannot load up a game from disc
Try to backup your data and preform a factory reset.
This will reinstall all programs and unit back to factory.
Feb 17, 2014 | Gateway NE56R41u Dual Core B960 4GB 500GB...
How to preform a factory reset
Step 1:
Restart your computer then press F8 key many times until the restore setting was appear. Do this before the windows logo appear. Then select Restore Mode and follow what was the instructions in the computer to complete the restore settings.
Step 2:
If not so, perform re-install of windows 8 operating system. Just insert the windows 8 DVD into your disk drive.
Step 3:
Or else you just reprogram the Operating System of your computer using the previous windows that you used.
Apr 05, 2013 | Computers & Internet
The process android.process.acore has stopped unexpectedly. please try again keeps appearing not allowing me to do anything but turn it off what do i do
I would preform a factory reset (note: this will erase all messages, contacts, settings, apps, etc.). To do a factory reset, go to: 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
I hope this helps!
May 07, 2011 | Computers & Internet
My neice did something and now the tablet is locked and its asking for a code which involves circles and some kind of pattern please help. its a apad android tablet
Hello, What you are seeing is the dot matrix lock code. Simply put: instead of a combination of numbers, the lock uses a pattern of "Connect The Dots" combinations. This is exceptionally hard to just crack without the proper knowledge and equipment. Instead of just designing it to wipe your phone/tablet, Google designed the lock to ask for you to log into your Google account after so many failed attempts, so that you can reset the combination. The easiest thing to do would be to intensionally guess incorrectly until this event occurs. If you have a problem with this, then the last-ditch solution would be to preform a factory reset. Should you need to preform this, please feel free to ask about how to go through the process. If you have any questions, please feel free to contact me, or simply reply.
Feb 17, 2011 | Computers & Internet
How do you reset the engine codes for a 1997 lincoln? can you replace factory cat with a preformance cat system, that won't screw up the computer monitoring. i have the 32v intech and the first bank is...
You'll need an OBD II scan tool to clear them. A performance cat replacement is fine. I would replace it, due to the fact that alot of times the insides of the converter break apart inside.
May 01, 2010 | 1997 Lincoln Continental
Preform service
consult your owners manual or contact your local dealer and ask for service dept, they will tell you how to reset the main req light.
Sep 05, 2008 | 2003 Jeep Grand Cherokee
Stop PDA from resetting itself
You need to Hard Reset your device to the deafult manufacter setup. This is easy to do, just open the user manual and read how to preform a ahard reset. Doing so should return the device to its initial factory setup where the on going resets should not happen.
Nov 13, 2006 | Audiovox XV6600 Smartphone
Nokia N97  Cell Phone Logo
194 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
