Question about Skil 2566 02 120V 14.4V Cordless Drill Usa
When i charge my battery. my drill only turn slow.not fast enough to drill a hole.
  • 7,733 Answers
Change the batts first and try.If the problem persist the change the charger,
Posted on Nov 08, 2010
Charger light blinks rapidly for dewalt charger?
usually indicates battery has failed slow blink charging steady red fully charged
Nov 03, 2017 | Dewalt Drills
When charging what does blinking green light mean 18v
ITS LOADING if green light RAPID BLINKING SLOW BLINKING YOU HAVE LI-ION BATTERIES THE BEST IS TO HAVE THEM ALWAYS ON THE LOADER IF IN USE ; THERE IS NO MEMORY EFFECT OR TRAINING NECESSARY THAT WAS THE NICKEL CADMIUM PERIOD OF THE HEAVY BATTERIES , when a li-ion battery is too long without charging and using on time when the battery is below the dc level it should have it is possible that the loader will not accept the battery anymore, no problem take 2 short wires of a powercable and from a full loaded battery take the + connector and connect to the + with the problem battery and also the - to the - and wait for a moment 4 or 5 minutes that should be enough so the deep unload protection level is high enough loaded to accept the battery again on the loader MAKITA HITACHI MILWAUKEE DEWALT and much more brands its the most safe solution to get that dead battery working again. because not always is there a real problem but when too long inactivity 1 or 2 years on a li ion battery it is not dead or have only used one battery too long without changing it
Aug 23, 2017 | Drills
Black and decker drill runs slow
Its much more likely that your batteries are not charging up properly. Ni-CD batteries suffer from 'memory effect' and can appear fully charged when only 70% charged. Also they lose charge when being stored. Do not short them out to discharge them! Wait until the drill complains that they are flat and then recharge them rather than when they first start to slow down. Do not let become completely flat (less than 1 volt).
Mar 03, 2013 | Black & Decker Black and Decker 18V...
I have a Nextec 12V cordless drill, when i press the trigger, the light flashes, but, the drill does not work. i have tried different batteries and have changed the settings and switches and it still...
At first it does sound like the batteries.
How old is the drill? If it's old, then the batteries may either be dead, or need a careful, slow charge overnight to charge them properly. If new, then they may also need a really nice slow charge.
Sorry to ask, but have you fully charged all the batteries you have tried? !!! Many rechargeables lose a great portion of their charge if they sit for a long time.
Also, when using the drill, never use it until it runs the battery down so far stops, as this can damage batteries or discharge them to where again you need to very carefully charge them to get full charge back again.
Have you overloaded the drill:any plastic smells or have you drilled too hard and stalled it for a long time? That could cause motor damage. But look to the batteries first.
Feb 21, 2011 | Craftsman Drills
How do i remove the hot start pluger from my yz450f as it seized in place and the top has snapped off the plunger?
with carby off the bike you can carefully drill into center of the plunger enough to get a small screw to grab into it when you turn the thread into the plunger. this is usually enough to gently twist and pull the plunger out ( use little WD40 or simular to help on the way out aswell)
The metal of the plunger is very soft so with new drill bit (small one ) it will be very easy to drill and cordless drill is best nice and slow and you want just enough hole to screw a small wood screw or simalar one ore two turns
Feb 01, 2011 | 2004 Yamaha YZ 450 F
I have a 14.4 volt cordless drill that when I try to charge the battery the red light goes from a slow to a rapid blinking after about 60 seconds. The battery does not hold a charge regardless of the...
One thing I,ve found with cordless tool batteries is that if they're completely dead, the charger won't recognize them. Try hooking a known good battery with a charge up to the problem battery, terminal for terminal, with small jumpers. Leave it hooked up for a minute, maybe a minute and a half. this should be sufficient to provide just enough charge to bring the battery up to the "threshold level" required for the charger to recognize it. Then, simply charge the battery in the normal way. If this doesn't work, you may need new batteries, or a new charger. Hope this helps you.
Aug 24, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
When I put the battery to charge the red LDc flashes as normal but then speeds up and flashes fast. The battery does not charge! any ideas?
the battery is bad, the fast flashing red indicated an internal short in the battery or it is consumed and needs to be replaced.
Nov 19, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drill stopped work ing when hot. One drill we bought stopped after 10 6mm holes. The others work when you pull the trigger and then sometime they don't.
Sounds like a burned out motor.
Sometimes you can replace the brushes and make them work again.
When operating that drill, make sure that you are not overheating the motor.
Depending on the material that you are drilling, you may need to use the drill on a slower speed in order to not overheat the motor.
Another way is to have more than one drill, and switch to a cool one as soon as you notice heat on the in-use drill.
If your drill is battery powered, stop using the drill and change the battery as soon as the battery dies enough to slow the speed of the drill.
Operating the drill under reduced power is very hard on the motor for several reasons.
Oct 28, 2009 | Milwaukee Tool Drills
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
CRAFTSMAN RDING MOWER, STARTER NO TURNING FLYWHEEL FAST ENOUGH IS SLOW
Your battery does not have a full charge resulting in slow turning over. Put a charger on the battery or take the battery to an auto parts store to be tested. Finally, your mower charging system may be the problem. Begin with the battery.
Jun 08, 2009 | Garden
Skil 2566 02 120V 14.4V Cordless Drill Usa Logo
97 people viewed this question
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
