Question about Samsung PS42A410 42 in. HD-Ready Plasma TV
I have a sound prob on my samsung PS42B. It sounds like one of the speakers has gone< but have had both replaced and the prob is still there.
    Brigadier General:
  • 8,909 Answers
Maybe the amplifier has failed?
Check for dry joints around the audio outpu IC and don't forget the headphone socket maybe intermittant, (if it has got one).
Hope this helps.
Posted on Nov 08, 2010
Samsung smart tv speakers sound horrible; this has just developed. The speakers sound "blown out" but we have never played the volume loud.
So then the amps have gone south and are in need of repair.
Or you can hook up your audio outputs to your external audio system - that should work. Did for me!
Aug 22, 2017 | Samsung Televison & Video
My Jaguar XJ Vaden plas side and rear radio speakers stopped working. What is the fix?
the norm prob is caused by the power amp gone down and burnt out the speaker coils, needs new power amp and new speakers. hope this helps
Feb 07, 2016 | Jaguar Cars & Trucks
Samsung 46 LED get sound no picture
it sounds like your back light inverter has gone. if its a led it could be built in on the power board. so check for bulging or leaking capacitors on the power board.
Jun 24, 2014 | Samsung LN-T4665F 46 in. LCD Television
Speaker
sounds like you my have a d2b fibre optic network problem or the head unit has gone down or the amp has gone u/s and blown all you speakers common prob..pick a speaker and test it with a ohm meter or a 1.5 v battery it should make a crackling sound if you connect a little battery across the terminals
Apr 23, 2013 | Jaguar S-Type Cars & Trucks
I have a Mitsubishi LT-52153 that has no sound. I have reset the tv as well as double and triple checked the audio input. i still dont get any sound from its speakers
Check in set menu and a box menu for the following:
Volume is not turned down or muted (both set and a box if used)
Speakers in the set are not switched to OFF.
If set has external hookup for speakers that is not selected (internal/external switch)
Lastly if set works with a DVD etc it has to be a setting either in the set or a cable or sat box or even a receiver if used causing this)
Apr 22, 2012 | Mitsubishi LT-52153 LCD TV
No sound from a Samsung HT-Q40?
It's part of an HTiB (Home Theater in a Box). Get the speakers that it's designed to mate with. HTIB's are not like components. Due to proprietary connectors and who knows what else under the hood, they are not intended to be mixed and matched with other units.
This unit has standard speaker connections so you might be able to find some speakers to hook up to it, but its original speakers were rated at 3-ohms impedance and the spec for the amp is also at 3-ohms. You probably won't blow anything up trying them, but don't expect earth-shattering volume from typical 8-ohm speakers. As the saying goes, individual results will vary.
How exactly did you expect the TV to be the speakers for this thing? It doesn't have an outbound audio connection. TV's are traditionally the part that makes pretty moving pictures while other electronics and speakers take care of the audio end.
If you need the manual, go to retrevo.com, register, find it using >>> Samsung HT-Q40 <<< and download it for free.
Jan 31, 2010 | Samsung HT-Q40 System
Centre speaker no sound. I can hear the surrounding sounds but no dialogs! checked connections and speakers: everything seems ok. Reset to factory settings, still same prob. I think the centre channelk is...
Well, maybe the center speaker is burned.Can you hear any sound from the middle speaker !?
If you can't hear anything from it, replace the speaker with the new ones.
If you can hear a minor sound or scratch, then the sound board inside the tv set is damaged.
Dec 09, 2009 | Televison & Video
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Samsung D840
Frnds, turning screen white and no sound from speaker are common problem of slider sets....these probs come bcoz of cuts in belt which connect two parts of slider sets....so u hav 2 replace that from service centre....
Apr 14, 2008 | Samsung D840 Cellular Phone
Samsung PS42A410 42 in. HD-Ready Plasma TV Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
