Question about Kenmore Washing Machines
Kenmore type 111 model 110 23812100 agitates but will not advance to drain or spin. When truning the dial it will only operate during the agitate cycle
jsrock516
  • 5911 Answers
SOURCE: Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Posted on Jul 10, 2007
  • 183 Answers
SOURCE: Kenmore Washer won't Agitate
gearbox internal fault, major repair, not really a do it yourself job.
Posted on Dec 25, 2007
  • 115 Answers
SOURCE: Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Posted on Dec 31, 2008
  • 97 Answers
SOURCE: 70 series Kenmore model 110 24712300 c40619231
Hello Friend, Your solution is very simple. You need to replace the motor coupler. It's easy to replace the motor coupler on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, just lay the washer on it's back. At this point you will see the water pump, motor, and transmission. Remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Now, remove the two screws that hold the two spring clips attached to motor. Unplug all the wires etc. and then snap the metal clips off motor. Lift motor straight up, it should slide right off. Now you will see the motor coupler. Half of the coupler is on the transmission shaft and the other half is on the motor shaft. There is a rubber center connector ring that connects the two together. Just remove the old coupler pieces by prying under them with slotted screwdriver and replace with new ones. Re-assymble the washer and the problem you are encountering should be solved. Happy to help, Tim.
Posted on Jun 25, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Posted on Jul 01, 2009
Kenmore Washer Will Not spin
replace door switch ,good luck APPLIANCES R EN
Mar 03, 2013 | Kenmore Washing Machines
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
I have a Kenmore washer model 110.26832690 that will not spin. It will fill up, agitate, but on spin cycle it will only drain. Does this sound like a bad lid switch or a bad drive adapter? From what I've...
if it agitates correctly,then its likely your lid safety switch, agitate and spin cycles are reversed by the motor during the cycles of agitate and spin,some units are wired to not operate on either agitate or spin,but some will operate on agitate with the lid open,but not on spin,open control panel and bypass the lid switch and this will tell you before you tear out the direct drive pump,motor and get to the d.d. coupler at the transmission
Mar 20, 2011 | Kenmore Washing Machines
Kenmore,Top load, series70 agitates in all Wash positions around dial. Dial advances as it should, then stops, will not pump water out. will not spin when dial is advanced .Fills, agitates,stops.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 29, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Goes thru agitate cycle then stops - no drain of water, no spin. Control dial does not advance but manual advance also not result in drain or spin. Position of dial on agitate area results in agitation.
If the drain pump is not operating correctly, the cycle will not continue. Also, sometimes the pump has something jammed in it, and may just need to be unclogged.
Sep 14, 2009 | Kenmore Washing Machines
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Dec 25, 2007 | Washing Machines
Washing Machines Logo
174 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
