Question about Philips DVDR3380/05 DVD Recorder
Date on dvd recorder keeps changing back to 2005
  • 687 Answers
You need to perform a firmware upgrade use this tip to help you
http://www.fixya.com/support/r3911602-dvdr_3380_firmware_upgrade_v3_27_divx_6
Posted on Nov 08, 2010
Date keeps resetting to 27.03.2011 I have tried unplugging,changing the date and going back to factory default and reinstalling but nothing seems to correct the problem therefore unable to use timer
Most DVR's don't have back up battery for holding setup data like your Computer. That means that you can never unplug or switch off the power supply completely. The clock runs off the mains supply so any interruption will make it revert back to factory settings.In other words you have to put it in standby mode when not in use to retain recording schedule / clock time etc.
Apr 10, 2011 | Daewoo Televison & Video
Toshiba rd-98dtkb hdd& dvd video recorder. Today I found that the date is showing 04/03/2010 instead of 01/03/2010. time is correct but when I changed the date it still goes back to 04/03/2010. anyone...
Sorry, dont have a solution, I have the SAME problem. Today is 01/03/10 but DVD player in EPG is showing 04/03/10 and has not taped today's programms set on series link. Can anyone help?
Mar 01, 2010 | Televison & Video
I have a Toshiba d-r18dtkb dvd recorder. Am
This is a known fault,solely affects toshiba dvd recorders and they claim is to do with the time/date signal it is receiving at the moment.They hope to have a solution by the end of the week(probably because it will be 04/03/2010 by then!).Call the tech support and log your fault on 08448560730.
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
Sony DVD Recorder not recording correctly
RETURN THIS ITEM UNDER WARANTY,DEMAND A REFUND AND PURCHASE A MORE UP TO DATE MODEL
Oct 23, 2007 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Doesn't hold the current date when turned off
There is a battery on the motherboard, next to the power supply connector, which may be bad or not connected securely.  That's the first place I'd look, although it should produce other symptoms, especially inability to 'remember' other setting, such as channel memory.
Sep 19, 2007 | Cyberhome DVR 1600 DVD Recorder
LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Philips DVDR3380/05 DVD Recorder Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
