Question about Car Audio & Video
The LCD lights on the display almost entirely gone out. Problem started 6 mo ago, graduallly more pixels went out. Then suddenly nearly all went out. It's a BMW 530i, 2003, with only 54k miles. Is there a fix without replacing entire radio?? How common is this problem?? Many thanx for your help.
    President:
  • 2,777 Answers
I have seen this happen a handful of times, it is not all that common. Unfortunately there is no fix aside from replacing the whole head unit, essentially the whole radio head display...
I found one here on ebay that will save you a good bit of change if you want to replace it:
http://cgi.ebay.com/ebaymotors/2001-BMW-5SERIES-RADIO-OEM-_W0QQcmdZViewItemQQhashZitem19bc6ea2ddQQitemZ110535549661QQptZCarQ5fAudioQ5fVideo
That should be the same radio to my knowledge, although there are a few variations. If it is not please let me know.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 08, 2010
My screen went out. Does this model have a replaceable backlight or must I replace the entire moniter?
Laptops have a replaceable LCD screen which is quite simple to replace, but are you sure the screen has gone out or is it the video card? I would start by plugging into an external monitor and see if the display shows on it before condeming the lcd display.
Oct 08, 2012 | Dell Studio 15 Laptop
Hello, I have a Compaq CQ60 and have problems with the LCD display, which works intermittently. I had the entire LCD replaced about 4.5 months ago. Worked great until a couple weeks ago, the LCD went...
is this a CCFL LDC
if yes the inverter is bad. (a card tiny, and thin)
its old LT.
the books are gone now.
the service book tells you how to replace the CCFL inverter
find a used good one is problematc.
why not buy a newer LT
or just run the external screen and be happy
I guess you have not read the user guide yet?
about the VGA hot key.
mine has.:
1: external only
2: internal only
3 both
4: auto. (i think only my newer HP has this)
mine is Fn+f4, but on a relic compaq, gee buy the book,
or google search for it for weeks,
next time post to HP< there is no COMPAQ for years.
hp owns it. totally
ever seen this before. the fail like LT batteries do. often.
http://www.ebay.com/itm/New-15-6-Laptop-Screen-LCD-Inverter-for-Hp-Compaq-G60-G50-CQ50-CQ60-Series-/251312052451?hash=item3a835d98e3:g:ARYAAOSwal5YJoxR
search there "compaq CQ60 inverter"
bingo.
when the sceen is dead do this.
see the flash light here, BINGO? bingo for inverter *****?
http://pcdied.com/black-screen.html#Dimbulbs
Mar 23, 2017 | Compaq Presario CQ60-212US Notebook
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Vertical line of dead pixles on Olevia 237T LCD HDTV
Replace the screen. It is faulty and is covered by your extended warranty. Any problems, contact your Trading Standards Office.
Mar 20, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Pixel gone
No this is whats called a dead pixel. Since it's white the transistor at that pixel area is shorted. Depending on the age of the unit the manufactor may replace the unit if not the whole panel will have to be replaced at a cost of more than the unit cost. Most manufactor says more then one pixel has to be bad before they will do anything.
Feb 10, 2009 | Proscan 26LA30Q 26 in. LCD Television
Laptop Compaq Evo N620c screen gone tiny!
dear do one thing as you have not mentioned whether you r using a laptop or desktop.........press the ctrl button on your keyboard & use the mouse scroll button up/ down..........hope this will resize the icons..........................Sameeraryan
Jan 02, 2009 | Compaq Evo N620c Notebook
I have an LCD TV. All of a sudden the picture colour has gone wierd. The best way to describe it is that it is similar to either a colour negative or one of those scientific 'false colour' images. This...
TFTs can produce a wide array of colors, but it takes an enormous number of transistors to make up a display, and a problem with any one of them creates a defective pixel on the screen. Typically this shows up as a bright spot on a dark background, caused by a damaged TFT failing to turn off a pixel. Most active matrix displays contain a few bad pixels, but a few bad pixels are not going to have much of an impact on the overall picture.
The properties of liquid crystal material can create problems with viewing angle effects, causing the image to darken, disappear, or reverse the dark and light tones when the viewer is not directly in front of the display (kind of like looking at the negative of a photo). The light bulbs make LCDs heavier than the plasma TVs (though they are still lightweights compared to CRT televisions.
Benefits of LCD TVs include a picture that can't burn in and doesn't deteriorate over time. Because of their flat-panel nature, placement options are plentiful, optimizing the cool factor over standard TVs
Apr 30, 2008 | Televison & Video
Slow turn, hot food
underneath the deck is a geared motor that turns the platter. check for non lubricated bearings or slipping gears.
Aug 22, 2007 | GE JVM1440 Microwave Oven
PDP-V401 Plasma
I am amazed it lasted that long. It could well be in the panel and would be expensive to fix. I think you would be better served at checking out a 40-42" LCD replacement. They've come a long way since yours was made.
Jan 06, 2007 | Pioneer PureVision PDP-V401 40 in. Plasma...
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
