Question about Apple M6496 17" CRT Monitor
Not turning on
The power button lights up orange/amber when u turn it on the power button changes colour but the screen won't turn on at all. You can hear the sound in the monitor (sounds like a relay switching contacts) any ideas
  • 1 more comment
  • hifiguytoo Jul 31, 2008
    same deal guys, seems to power up ok but no image, also power button flashes orange, any ideas ?
  • Anonymous Aug 07, 2008
    YIKES!
  • mstrmsn
    mstrmsn Nov 14, 2008
    exact same symptoms. I have plenty of parts, with what should I begin?
Mine is doing the same after it rained on it........
Posted on Aug 07, 2008
  • ask_not Apr 21, 2014
    Replace the inverter.
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Dell W2607C LCD TV won't turn on
Check and replace its main power regulator board. It might be faulty. Normally there is no repair to these boards. Card base replacement should be done.
Feb 07, 2013 | Dell W2607C Television
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Turn on only orange lihgt but won't boot up
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jun 12, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
My dell pc still not working
An orange/amber light is almost always a power problem. Is the amber light on the monitor or the PC itself? I'm assuming the PC since you have the ability to read the screen. Your best bet is to check your power supply in the PC. Do you have a power supply tester (about $20) or another PC? You can switch them out and see if the orange light follows the power supply. Let me know what you find out.
Feb 11, 2009 | Dell OptiPlex GX260 PC Desktop
Apple M6496 17" CRT Monitor Logo
164 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
