What is the best choise for designing HVAC system for air flight simulator building, the space area is 700 m2 and the heigh is 9 m
  • 455 Answers
Hello,You need between 12 1/2 ton unit minimum or 15 ton depending on the heat output of the simulator equipment.maybe 2 (6)ton units need blueprints for recomendation.
Posted on Nov 08, 2010
Loaded but wont run when activated
Check this link for more info...
Also don't know your OS ?
Flight Simulator 2004 doesn't run correctly on Windows 8. It runs on my Windows 8 laptop bought in April 2013. But, none of the aircraft, including any add-ons, show up in the preview window - it is always black. Also, If I download weather and try to save a flight, when I go back to that "saved" flight, it always reverts to the default flight with the Cessna @ the default airport. If anyone knows how to make the flights save, on the Windows 8 platform, please let me know - likewise, with the aircraft previews. Flight Simulator 2004 did quite well on the Windows XP platform for me.
Apr 18, 2014 | Microsoft Flight Simulator 2004 Update
I have downloaded Microsoft 737 Professional after downloading Microsoft Flight Simulator X (required in order to use Microsoft 737 Professional -
May look in AVG quarantine and see if any of the &#& is in there. You can have AVG disregard certain folders that it may think are virus's.
Mar 03, 2014 | Just Flight 737 Professional - Expansion...
Just purchased saitek yolk with throtle but its not working ,.tried calibration still does not work
I had a friend with exactly same issues, only he used a CH Flight Yoke system.
Calibration can be very tricky sometimes, and it has very often to do with how the configuration file has been set up.
You might have to rebuild your configuration file for your Flight Simulator before it will work properly.
However here is some hints for calibration fix from Saiteks UK support.
Maybe this can solve your problem, understanding how to make a valid configuration file for Flight Simulator.
http://www.saitek.com/uk/supp/yokefsx3.html
Good luck
Aug 24, 2011 | Saitek Pro Flight Yoke System Flight...
I have 64 bit system. is ms flight simulator 2002 compatible with that?
MS Flight Simulator 2002 should be compatible with your 64 bit operating system.
It should, SHOULD, normally install.
If you have troubles running the program, I suggest right clicking on the shortcut and run it in XP SP2 compatibility mode. But, you shouldn't have to do that.
Mar 12, 2011 | Microsoft Flight Simulator 2002 Standard...
What is hvac
Hi, Hvac that i know is (Heating, Ventilating, and Air Conditioning) refers to technology of indoor or automotive environmental comfort. HVAC system design is a major subdiscipline of mechanical engineering, based on the principles of thermodynamics, fluid mechanics, and heat transfer. Refrigeration is sometimes added to the field's abbreviation as HVAC&R or HVACR, or ventilating is dropped as in HACR (such as the designation of HACR-rated circuit breakers).
HVAC is important in the design of medium to large industrial and office buildings such as skyscrapers and in marine environments such as aquariums, where safe and healthy building conditions are regulated with temperature and humidity, as well as "fresh air" from outdoors.
Heating, ventilating, and air conditioning is based on inventions and discoveries made by Nikolay Lvov, Michael Faraday, Willis Carrier, Reuben Trane, James Joule, William Rankine, Sadi Carnot, and many others.
The invention of the components of HVAC systems went hand-in-hand with the industrial revolution, and new methods of modernization, higher efficiency, and system control are constantly introduced by companies and inventors all over the world. The three central functions of heating, ventilating, and air-conditioning are interrelated, providing thermal comfort, acceptable indoor air quality, within reasonable installation, operation, and maintenance costs. HVAC systems can provide ventilation, reduce air infiltration, and maintain pressure relationships between spaces. How air is delivered to, and removed from spaces is known as room air distribution.[1]
In modern buildings the design, installation, and control systems of these functions are integrated into one or more HVAC systems. For very small buildings, contractors normally "size" and select HVAC systems and equipment. For larger buildings, building services designers and engineers, such as mechanical, architectural, or building services engineers analyze, design, and specify the HVAC systems, and specialty mechanical contractors build and commission them. Building permits and code-compliance inspections of the installations are normally required for all sizes of buildings.[citation needed]
The HVAC industry is a worldwide enterprise, with career opportunities including operation and maintenance, system design and construction, equipment manufacturing and sales, and in education and research. The HVAC industry had been historically regulated by the manufacturers of HVAC equipment, but Regulating and Standards organizations such as HARDI, ASHRAE, SMACNA, ACCA, Uniform Mechanical Code, International Mechanical Code, and AMCA have been established to support the industry and encourage high standards and achievement.
Hope is the one your talking about.
Fill free to pass your comment...
Feb 14, 2011 | Cell Phones
I wanted to configure a system suitable for flight simulator so what can be the better config..
just read minimum configuration for that game, and you build it for required configuration, or above that. ( i will go above) i dip pends how much money you are willing to spend. I am right now of making configuration for my little brother, and i am thinking to go with dual core - for processor ( intel will be the choice above 2.8 ghz) 4 ddr 2 g ram, and some graphic of 512 mb ram... nvidia or ati... still got to do more research. Tell me how much money you are willing to spend and i will make you best config....
Apr 30, 2009 | Microsoft Flight Simulator X for Windows
Microsoft flight simulator x
Try entering it with spaces and without spaces. Also, upper & lower case letters where they are different.
Feb 13, 2009 | Microsoft Flight Simulator X for Windows
How to tell if computer hardware will be sufficient for Flight Simulator X
From the specs you have supplied, your friends computer should be able to run FS X just fine.
Matt
Apr 16, 2008 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
