Question about Xerox Phaser 8560MFP Laser Printer
I have a HP 2840 Printer. The printer is leaving black roller marks on my print documents.
  • randalo Nov 08, 2010
    Still having the same issue. Printed copies have roller streaks and color blobs splattered on the sheet.
  • 2,973 Answers
The roller must be cleaned thoroughly.
Posted on Nov 08, 2010
  • 340 Answers
Solutions for : Roller Marks on Prints Solution : Clean the Printer and Paper Trays Feed Rollers NOTE: Use 90% isopropyl alcohol and a lint-free cloth to clean the rollers.
  1. Open the Exit Cover.
  2. Clean the gray exit rollers, and then close the cover.
  3. Open Paper Tray 1 (this is the manual feed tray), clean the gray pick roller, and then close the tray.
  4. Clean the pick and separator rollers in Paper Trays 2, 3, and 4.
    1. Open Paper Trays 2, 3, and 4 and pull the trays completely out of the printer.
    2. Locate the release lever to the right of the gray pick rollers in the printers I have a HP 2840 - 8500-release-lever.jpg8500-release-lever.jpg
    3. Pull the lever to let the rolI have a HP 2840 - 8500-release-lever-pull.jpg />
    4. Grasp and pull the rollers I have a HP 2840 - 8500-rollers-remove.jpg them from the printer .
    5. Clean the rollers with clear packing tape. One method is to lay a strip of clear packing tape, sticky side up, on a tableI have a HP 2840 - 8500-rollers-clean.jpge pick assembly along the length of the tape.
    7. Replace the roller assembly.
    8. Re-install the trays and make sure to completely close the trays.
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
How can I override the calibrating mode on A HP LaserJet 2840 All-In-One printer. My black toner is out and it would not print any documents, keep saying replace toner can I override this until I purchase...
You Cannot override, as the black cartridge is required for all print functions. Both B/w and Color use the black, obviously in smaller amounts in color, but it still requires it none the less. Sorry, I know you were hoping to trick the printer somehow, but with HP printers it's not an option, especially on the Laser Printer models like yours.
Dec 15, 2010 | HP LaserJet 2840 All-In-One Printer
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
My hp laserjet 2840 is printing reams of gobbledy
Looks like you have a corrupt print file. Delete all of your printer documents in the queue, shut off the printer and unplug the ethernet connection and the printer (from the wall jack) for about 30 seconds. Plug everything back in and try again.
Note: If this happens again, narrow down the specific file that's causing it and don't print with it. I've seen webpage PDF's cause this problem in a number of HP's.
Aug 10, 2009 | HP LaserJet 2840 Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
My HP Laserjet 2840 all in one beeps when printing
unfortunately, your printer uses all of the carts even for just black prints.
press the check mark key and scroll down to diagnostics.
select disable cartridge check
But then you won't know when you're out of a certain color.
Feb 02, 2009 | HP LaserJet 2840 All-In-One Printer
Scanning not happening in Hp lasejet 2840 in windows vista
check to see if that printer requires direct plug into wall socket. and did that printer driver come on cd or did you get it from www.hp.com?
Dec 12, 2008 | HP LaserJet 2840 Printer
HP printer 1200
Question: Which roller did you clean?
Jan 26, 2007 | HP LaserJet 1200se Printer
Xerox Phaser 8560MFP Laser Printer Logo
185 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
