Question about Apple iPod shuffle MP3 Player
Ipod my ipod is not opening why
  • Apple Master
  • 13,433 Answers
Forgot my ipod password
Which version of ipod 3rd 4th or fith gen >??????
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open.
If you need more help with this post a reply.
Nov 10, 2013 | Audio Players & Recorders
Tip
How can I open my iPod on my Mac Desktop?
<p>When you connect your iPod to your Mac desktop or laptop computer, the iPod name and the icon on the desktop. Most people have no opportunity to open the iPod from the desktop to iTunes music on a regular basis, generally have short, any securities, making them difficult to recognize. However, if you use your iPod in disk mode - basically a portable hard drive - to open your Mac desktop is the fastest way to open the files. <br /> <p><br /> <p>1. Connect the cable from the iPod charger to the bottom of the iPod and the other end into a USB port on your Mac should be noted that the iPod shuffle is upside down in the dock. <br /> <p><br /> <p>2. Wait until the iPod appears on the desktop. If not, pull and plug the charger cable, sometimes it takes a couple of tries. <br /> <p><br /> <p>3. Double-click the iPod icon on the desktop when it appears. IPod open up and show your files. <br />
on Aug 09, 2011 | Apple iPod touch
Ipod classic won't sync with itunes 10
Restarting your computer is often the solution when your iPod fails to sync with your iTunes music library. But if this fails, there are other troubleshooting steps to take.
Recharge your iPod via a USB cable connected to your computer or AC adapter. b> Click the help menu in iTunes and check for updates. Follow the onscreen prompts to download and install the latest version of the software. Open the new version of iTunes. Click the name of your iPod in the source list and check for updates under the summary tab to update your iPod. Attempt to sync your iPod with iTunes. Slide your iPod's hold switch to the hold position and then to off. Press and hold the menu and center buttons simultaneously until the Apple logo appears to reset your iPod. Open iTunes on your computer and reconnect your iPod to try to sync it with iTunes. Restart iPod service b> Close iTunes and make sure your iPod is disconnected from the computer. Click the 'start' button. Click 'run' if using Windows XP. Type 'services.msc' in the run box in XP and in the search box in the start menu in Windows 7 and Vista. Press 'enter.' Scroll through the list and double-click on 'iPod service.' Click the 'stop' button and leave the properties window open. Connect your iPod to the computer. Open 'my computer' or 'computer' and look for your iPod listed in the devices with removable storage section. Click the 'start' button in the iPod Service's properties window. Open iTunes to attempt to sync your iPod. Close the iPod Service's properties window once your iPod has finished syncing. Resolve "Original File could not be Found" Double-click the name of a song in the iTunes program that failed to sync to your iPod. Click 'yes' or 'locate' to the message asking you if you want to locate the file. Navigate to the folder or directory location where the song is stored on your computer. Double-click the song file to select it and add it back to iTunes. Reconnect your iPod to the computer and open iTunes to restart the syncing process. Some songs in iTunes won't copy to iPod http://support.apple.com/kb/TS1420 iPod classic Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/classic/
Apr 12, 2013 | Apple iPod MA446LL/A MP3 Player
Code to unlock
This works on an iPod 5 th gen Click start control panel scroll to folder options tick in the box to show hidden files and holders
Mar 02, 2013 | Apple iPod MA446LL/A MP3 Player
Locked
Step 1:
Feb 11, 2013 | Apple iPod nano MP3 Player
Ipod forgot lock pin
Hope this helps.
Jan 21, 2013 | Apple iPod nano
Forgotten pin for my ipod and cant open
click start control panel scroll to folder options tick in the box to show hidden files and holders
click start click click on you Ipod to open
right click select rename to open or delete the folder your Ipod should now be open
hope this helps
Sep 30, 2012 | Apple iPod touch
I have apple 60gb ipod, ipod is not to open it is an locked , now the open its locked
Hi jatinpate169...
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please take time to rate me
Jul 30, 2011 | Apple iPod Weiss (60 GB) MAC/PC -...
How do i upload my music to my nano ipod 4gb to my pc
Connect Your ipod to PC with USB cable.
If you have music in your PC directly copy to your ipod
-If you connect ipod to pc, it will automatically open ipod memory open and copy from your computer to ipod.
If music not in your PC, download from internet.
Feb 03, 2010 | Apple iPod nano
When i connect ipod to my laotop it open as apple ipod but the y shows like camera&scanner. why my ipod is not opening through?
Before your laptop can recognize your device i.e. your ipod touch you need a driver for this device, you can downld it from itunes website. After you have downlded this driver install it then re-connect your ipod device to your laptops usb hub.
May 24, 2009 | Apple iPod touch Second Gen (8 GB,...
Apple iPod shuffle MP3 Player Logo
16 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
