I lost my UPC SSID password. Is there any way i can get the password via the SSID?
  • englishvalet Nov 08, 2010
    no, there is no way to get password via SSID. Is there any vista computer before that was connecting fine with the router wirelessly? What is the model number and brand of your router?
  • 22 Answers
What you search isn´t there for upc at the moment.
If you sometime loose another password (wich is written on the router bottom itself ) and you got a thomson, speedtouch, Orange-, INFINITUM, DMAX or Bbox ssid with "serial" in it
you will find your password here too and don´t have to get up from the couch :-)
but !! its a good idea to find out if your internet connection has flatrate before using it.
there are some very crazy ISP´s what do an autologin just away from the router, which is used, and you can see `your user data on the ISP´s website which will tell you about your contract and hopefully an flatrate ..
otherwise you know what you are, and something will happen anyway from high bill receivements...
ahm, whatismyipaddress.com will tell you your ISP if have forgotten, which it was.
so now thats it, be kind or your karma will stop being nice to you ;-)
Posted on Feb 24, 2011
SSID
Hi John,
The SSID is either broadcast or sheilded, depending on whether the owner wanted to broadcast it or not. Many people often choose to shield the SSID as another layer of security for their WiFi. The SSID is needed to recieve a prompt for security keys, so without the SSID, you're stuck to look for another WiFi signal.
If the WiFi router is accessible to you - that is; you own it - you can access the router's setup page via any computer that is either 1) physically connect via network cable, or 2) connected via WiFi. You will need to point your browser at the router's setup page - often 192.168.0.1 is used. You will be prompted for a username and password. You didn't provide the model number of your router, but according to this Arris Router manual I found, if it was not changed from the factory default by the user - it will be "admin" and "password" (without the quotes). From here, you would go to the wireless settings to read or change the SSID and security settings.
If the router refuses the admin / password credentials, that means that it has been changed from the factory defaults. It will not be possible to view the router settings, but you can return the router back to the factory settings by locating the reset button on the device itself. With a paper clip or ball point pen, press and hold the reset button for several seconds, then release. This will remove all customizations to the router settings.
Using the manual as a guide, you can edit any of the settings as desired, but you should at least change the login password to something unique and set the WiFi security to WPA with a security key (word) that does not appear in the dictionary. Use WEP security *only* if there is no other type offered, as WEP security can be hack in under a minute or two by computer. As you can see, not broadcasting the SSID provides an additional layer of security. You can broadcast it is you wish.
Finally, record the the IP address, username, password, SSID, security type and key and attach to the underside of the router. Should you forget the info needed to access it in the future, you'll find everything you need on the label.
I hope this helps & good luck!
Jan 29, 2013 | Arris Computers & Internet
Password cant find
reset the Linksys to default settings, reconfigure SSID and Security Key. You can find a user manual here: http://cna1.upc.edu.cn/cisco/tools/WRT160N_ug.pdf
Jan 25, 2013 | Linksys WRT160N Wireless Router
Lost password and i cant use my ipohne with router.
Modify the router's settings.
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing www.fixya.com and kindly rate this post.
Jan 03, 2012 | Linksys WRT110 Wireless Router
Dir-601
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 or 10.1.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing fixya.com and kindly rate this post.
Jan 03, 2012 | D-Link D Link Dir 601 Wireless N Home...
Did I give the wrongpassword?
Are you trying to connect wireless? Have you check if it will work via hard wired cable connection? If you want you can check for the configuration settings of your router and check if internet will work after these steps.
Dec 28, 2011 | Westell Wirespeed VersaLink...
I lost my password how can I change it?
Dec 28, 2011 | NetGear N150 RANGEMAX 150 Wireless Router
I lost my passcode for my d-link DIR-601 router can i get my passcode ?
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 or 10.1.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option, here you can check what is your router passcode or if you want to change it to anew one you can chage it as well8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you are good to go.
Dec 25, 2011 | D-Link Computers & Internet
Lost my Wireless name (SSID) lost my Security Passphrase
1. Open your internet browser.
2. Type in 192.168.0.1 and press enter.
3. When prompted, type in admin for username and password for password. That should get you into all of the settings, where you can view your wireless network's SSID and security passphrase.
4. CHANGE your username and password. This is how hackers access your network!
Jul 25, 2011 | NetGear DGN1000 Wireless Router
Have labtop computer but for somereason computer
The owners manual should tell you how to do this but below is a summary.
Connect to your router via the cable connection by typing in the ip address of the router. Note the SSID, Password and security settings. Also make sure WLAN is transmitting via WiFi.
Disconnect pc/router cable.
Activate your WLAN at the pc
Make sure you can see your SSID from your Laptop.
Make the connection by clicking on your SSID and enter the required password and security settings.
Sep 27, 2009 | Linksys RangePlus WRT100 Wireless Router
HP C4180 Wireless printer lost network connection
You were probably piggy-backing on someone else's router, and they changed names, passwords, etc. But if you have a cell phone and internet access with that cell phone, you can set such a cell phone up as a hot spot (sharing internet connection)! The cell phone will tell you the SSID #, as well as the password which you will have to enter into the HP printer to let it connect.
May 08, 2017 | HP Photosmart C4180 All-In-One InkJet...
Computers & Internet Logo
777 people viewed this question
David Payne
David Payne
