Question about Sony Cyber-shot DSC-W80 Digital Camera
Reinsert the memory stick...
I loaded my pics on my computer just sticking the memory stick in it. After they all loaded when putting the memory stick back in the camera it say "reinsert the memory stick" I have tried taking battery out, turning camera off an on nothing will work. The memory stick still works and pulls up all the pictures in my computer though?!?
  • lmb32481 Jun 16, 2008
    PLEASE HELP!!!
  • househunt Jan 14, 2009
    that did not work
  • 74 Answers
You will need to re formatt the card and this problem should be solved
Posted on Aug 12, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
I want to transfer 525 pictures stored on my computer to a memory stick. how do I do this?
Plug the memory stick into the computer and format it. Unplug it then plug it back into the computer, you should have a pop up that asks you what you want to do (open folder view, play and a few other options), you weant to choose Open a Folder View.
You should now have a window open that you can put files into, if not then go to "My Computer" and select it from the available drives.
Now open up the folder with your pictures in it and select all the pictures you want to transfer then press "copy". Go to the memory sticks folder and right click and select "paste" from the right click menu or hit "CTRL+V".
You will get a progress pop up that shows how long the file transfer will take, after it is done...so are you.
If the memory stick is not recognized when plugged in, you way need to load the software that came with the memory stick for its drivers.
May 04, 2010 | Dell Dimension 2400 PC Desktop
My memory stick does not have a lock or unlock position.
Do not use the computer to erase a memory stick. If your pics are safely on the computer and you want to completely erase the stick, use the format function in the camera.
Apr 25, 2010 | Sony Cyber-Shot DSC-P92 Digital Camera
Reinsert memory stick
Are the contacts on the card clean? Is the slide switch on unlocked?
Sep 13, 2009 | Nikon Coolpix 990 Digital Camera
Pictures stored on card, and unable to retreive them on camera
Have you tried accessing the pictures via a card reader connected to your PC. It is possible the card is damaged and you will not be able to recover your pics. But it is worth a try. If you do not have a card reader take the card to a camera shop and see if they can see and manipulate the pics to another card, then reformat the card and reinsert it to see if it then reads anmd writes.
Jul 22, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Cannot get my photos from memory stick to progess beyond the 1st 5 photos. they keep repeating. I never had a manual.
Hi there.
1st) How did you put the photos on your stick? Did you load them from a computer, or did you load them off a camera?
If you loaded them off a camera, did you format the card before you took the pics, or before transferring them from the camera's internal memory? You have to do format the memory card from the camera menu before it will work properly.
If you used a computer, same thing, you need to format the stick before you transfer photo's to it. Try it and let me know.
Rob
Mar 03, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
SanDisk Memory Stick Pro Duo problem
it may be lost, safely remove your hardware befor you get off from the computer
Nov 02, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
SONY CAMERA DSC-P52
have you tried formating the memory stick on the computer and see if that works? how did you put the pictures on the computer? via the USB that came with the camera? or did you use the memory stick and put it into the camera?
Nov 11, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
823 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
