Kenmore washer just stopped
I started a load of laundry and my kenmore 24642 top load washer just stopped after it was filled. It won't do anything and I have confirmed that the electrical outlet is working and tried putting it on another cycle. I have had it for about 3 1/2 years and never been serviced. My Washer will fill up with water and then stop, it will not start a cycle. The first time it did this to me was last sunday, then on tuesday is started working again. Last night I put a load in and now I have a washer full of water!
  • 5,911 Answers
This is a typical symptom of a defective or loose lid switch. If you open and close the washer lid, you should hear a clicking noise as the lid switch activates. The lid switch is usually located on the right-hand side under the washer casing rim. It is activated through a small slot, by a plastic piece on the lid called a lid strike. There are two mounting screws adjacent to the slot that hold the lid switch in place. Sometimes the screws come loose, or the lid strike breaks off, causing the switch not to activate. Or..the switch simply fails over periodic use. This results in the symptoms you describe. The washer fills, but fails to spin or drain. This is a simple repair that you can accomplish yourself. For step-by-step instructions, please refer to the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require assistance in locating replacment parts and/or have further questions, please post back with your complete model number (located aorund the tub rim), along with your comments. That way I can assure the accuracy of any part numbers.
NOTE: Use care not to slam the washer lid. This can also cause premature failure of the lid switch components.
Posted on Jun 16, 2008
Kenmore washing machine will not stop filling
There is a water level sensor in the tube and it might be plugged. IT could also be the load selector or the control module.
Feb 10, 2014 | Kenmore 22642 Top Load Washer
Washer filled with water but won't do anything
AT the time that you describe, the lid switch must be closed. Check that switch.
Jun 25, 2011 | Kenmore 24722 Top Load Washer
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Washer does not fill quickly for rinse cyle
check your water pressure if its good check the valve on the back of the washer to see if anything is stopping it up . you may have to replace the water valve
Mar 29, 2009 | GE WBSE2090A Top Load Washer
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, check/replace lid switch. Also try tightening the lid hinge screws on the left side. if these screws come loose, the machine will not operate
Jun 14, 2008 | Kenmore 24642 Top Load Washer
It won't agitate
after it fills do you hear any sound and does it go to spin on its own or do you turn the timer your self it could be a bad pressure switch thats what we are trying to determine
Feb 12, 2008 | Kenmore 24642 Top Load Washer
Open Questions:
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
