Question about Aurora Electronics AS2000CD Shredder
The flashing red light is on and we have cleaned the teeth several times and there appears to be nothing stuck in the unit. With the unit upplugged we pull excess paper out and down in the bottom we found 2 wires. Would that be the problem? or if the red light is flasshing is it something else?
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Canon mp500. The ink cartridge will not light up and the unit will not recognize it. I do not have the old cartridge and this is the third cartridge I have purchased this week. I want a solution; not...
Hey..
I had this same problem before..
And I already solved it..
There is 2 probabilty
1. Your cartridge chip (the small one) is messed up or dirty, try to clean it..
2. (Most caused this problem) Your printer cable that detect the cartidge chip is dirty or unplugged.. Try to clean that..
U will know the location of this cable if you attach the cartridge, and u will notice red light appear.. If light doesn't appear then it's the problem.. Or the light appear but not to strong like the other cartrige attached.. The red light will always flashed..
Try to push the cartridge until the full power flashed red light appear, if your hand left it (unpushed) and the red light become low again, try to clean the cable with cotton bud or tissue, if u clean it with cotton bud u will heard "click" sound.
I called this problem "Red Light Of Death" (RLOD)
Nov 24, 2010 | Canon Pixma MP500 All-In-One InkJet...
I have a technika lcd tv/dvd. It is only a few months old but it is stuck in standby with the red light on the front continually flashing and will do nothing else. Any ideas?
I have same unit (which works in my case) but the red light does not flash on 'Standby', only when it is seeking a station after pressing the red button on the remote.
Nov 16, 2009 | Televison & Video
Paper won't feed into shredder
maybe a security feature needs top on to run.
Jun 10, 2009 | Cross Infoguard Shredder SX102M
On the display screen it flashes clock and what ever buttons you push nothing happens
not exatly shure how it was done all I did was uppluged the unit cleaned it and replaced a burnt out bulb and it works
Sep 21, 2008 | Microwave Ovens
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Aurora Electronics AS2000CD Shredder Logo
101 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
