Question about Intel Motherboard
Intermatic "Little Gray Box" water heater timer.
Why is my motor making a loud clicking noise? I have power when I switch it to the "On" position. Switching the "Off" or "On" switch does not change the clicking sound. I have not used this since I
1) Question posted under T101 Intermatic 120Volt timer.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) Blow out timer with compressed air.
Turn power off, and spray highly flammable WD40 vapor onto timer parts.
Wood surface will carry sound, like a guitar or violin ... apply sound deadening material between timer and wood surface.
Apply bit of white grease to motor gears.
Treat timer as any other electrical appliance and keep timer door closed to protect agains fire hazard.
3) Add comment and say what product you are talking about and what you have done so far.
Jan 05, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
If the little gray box has no trippers, the dial does not rotate,and the lever is on, is electricity being conducted to my water heater?
Maybe yes.
Open TP valve on water heater and see if heater has hot water.
If you want to test, then test across wires on terminals 2 and 4 for 240Volt. Test across terminals 1 and 3 for 240Volt.
To fix timer, buy new WG1573 240Volt clock motor.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Gene
h
Jan 02, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
Need t173 part for intermatic hot water heater timer
Open following link for T100 series parts:
The T173 timer is 120Volts and wires same as T103.
Only difference between T173 and T103, is the T173 has day-skipper wheel
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Jun 24, 2012 | Intermatic T101 - 24 Hr. Dial Time Switch...
I just moved in to a new house and the water heater is hooked to an intermatic T 171 timer. I have set the trippers in different positions and the time of day is correct, but I still cant get hot water...
Open following link for Intermatic troubleshoot checklist.
Once timer checks out, you need to check circuit going to water heater.
Water heater might be the problem.
Remove trippers from timer dial and set override lever to ON.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 01, 2011 | Intermatic T171 - 24 Hr. Dial Time Switch...
WH40 water heater timer: Does black wire from service box go to terminal #1 and black wire to water heater to terminal #2? Does neutral (white) from service box go to terminal #3 and neutral (white) to...
WH40 is 240Volt timer.
WH40 will not work with 120V circuit.
See WH40 wiring illustration at following link:
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
There are two hot wires in 240V circuit because every circuit requires two wires to complete the circuit.
Hot wires from breaker connect to terminal 1 and 3.
Notice that small white wires are also connected to terminals 1 and 3.
Small white wires power clock motor located on back of mechanism, so this says power from breaker box must arrive on terminals 1 and 3. This insures that clock motor runs continuously.
If clock motor only runs when manual override switch is clicked ON, then your Hot and Load wires are reversed.
Bare ground wire connects to green ground screw.
Wires going to Load (water heater) connect to terminals 2 and 4.
FYI: Terminal A is not used unless circuit also has a Neutral wire,
See basic water heater circuit Diagram #2:
http://waterheatertimer.org/240-v-water-heater-circuit.html
Terminal A is also used if you want to convert WH40 to 120V timer by replacing 240V clock with 120V clock.
How to convert Intermatic 240V timer to 120V timer
http://www.fixya.com/support/t7353947-intermatic_timer_wg
Dec 24, 2010 | Electric Intermatic Inc Wh40 Water Heater...
I HAVE AN iNTERMATIC t100m TIMER it appears to have two "off" tripper levers but no "on" tripper lever attached to the clock face dial by a set screw . Do I need an "on "...
Yes, the T101M 120Volt pool timer requires both ON and OFF trippers:
Grainger sells T100 series on-off trippers:
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Amazon sells T100 trippers
http://www.amazon.com/dp/B003YO2C5U/?tag=picc-20
Grainger sells the T100 125V clock motor
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T-101 120Volt timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
How Intermatic dial timer clock works.
Clock motor rotates dial.
Intermatic clock motor, located on back of mechanism, are replaceable
Trippers located on outer edge of dial push on-off lever
ON tripper pushes lever one direction
OFF tripper pushes lever opposite direction.
Lever pushes electrical contacts together and pulls contacts apart.
When lever moves, manual override also clicks back and forth with audible click.
To replace timer, replacement snaps into box without needing to changing box.
Dec 10, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
The timer is used on an Electric Point of Use 2.5 water heater. Currently I get hot water only about two hours in the evening. Before it was --on demand. I opened the timer box and one of the timer box"...
No overcharges here Ms bernarda
If I understand correctly you have Intermatic timer with a yellow dial
You have the Intermatic timer hooked to a small 2-1/2 gallon point-of-use water heater
Your point-of-use water heater is working fine
The timer turns on the water heater once a day instead of twice a day
And it seems like one of the tripper pins has fallen off the yellow dial
The tripper pin is missing and you can't find it or put it back.
You can turn off the electricity and poke around the bottom of the timer box and see if tripper pin can be pulled out using tweezers
Do you know Grainger sells Intermatic tripper pins for $1.67 plus shipping?
Now, if this is not the right answer, you post a response and we can probably help
Oct 21, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Manual lever setting for water heater timer
post a close up of the timer and i will tryto assist you.
normally it dosent matter where the lever is as it should reset itself after each comlete operation . ie if you turn it on it should turn off when it reaches a preset off cam pin. or position indicator lever.
Nov 25, 2008 | Intermatic WH40 - Water Heater Time Switch...
Intel Motherboard Logo
357 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
