Question about Microwave Ovens
How to use a candy oven model FPP 403N - Microwave Ovens
How to set clock on candy pinkDunelm microwave
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Jun 06, 2016 | Candy Microwave Ovens
Light bulb replacement
on this you have to remove the outer case which is not adviseable
Mar 27, 2014 | Candy Microwave Ovens
Microwave plate turns but does not heat anything
The magnetron is bad. This is the radar wave producer that excites molecules and makes things cook. It is a replaceable part but you may find purchasing a new one is more desirable. Why? A magnetron for a popular model microwave that is 1-3 years old will cost about $50-60. If it's an old one it can cost $189 and hard to find one available. And if it was mass produced in China with a no-name brand you probably won't be able to find parts much less customer support. Also, if one component has gone bad it won't be long before another goes bad. Good luck.
Mar 14, 2014 | Candy MIC201EX 800 Watts Microwave Oven
Way too loud beep
Not the sound normally you can NOT adjust. Maybe your problem arise in two ways: a) Magnetron defective b) Triac defective. Call to service tech for diagnose the problem.
God bless you
Jul 31, 2012 | Candy CMG7517DS 700 Watts Microwave Oven
I need instructions on how to make candy floss in my sunbeam fairy floss maker, please.
Thank you for posting on FixYa. I might be able to help if I knew your model number.
Jun 04, 2011 | Microwave Ovens
MICROWAVE NOT HEATING ITEMS IN OVEN FAN AND CLOCK ARE WORKING
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 09, 2011 | Candy MIC201EX 800 Watts Microwave Oven
My candy microwave oven with grill and convection.model:CMC 2895 DS. Is rotating but food dont get heated when microwave is set. Then later ater the service man had removed the cover to check where the...
If it is still new and under warranty, the best answer is to exchange it immediately! It sounds like you got a defective unit with either a bad magnatron, a bad power supply, or bad control circuitry. If you had a service man look at it and it is even worse now, you really need to exchange it. If you try to fix it yourself you will void the warranty.
Mar 25, 2011 | Candy Microwave Ovens
INSTRUCTION MANUAL FOR CANDY FLO100X SINGLE CONVENTIONAL OVEN
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 01, 2010 | Microwave Ovens
I have been trying to melt candy wafers for making candy molds. I melt at 50% power but I can never get it fully melted so it can be poured. I have tried 80%, 90% and 100%
please stop this silly game, its going to blow up your microwave in no time at all candy is darn nearly all suger and very little water in it,dont keep running your microwave like this its like runing it with nothing inside of it, it will age the megotron and it will then not work at all,,
a pricy mistake to make, just stick them in the oven,,,gas one that is?
or if your brave,,,, try a blow lamp, that works very well if your not heavy handed with the flame,,,,but if you keep on punishing your microwave like this its going to go with a big bang on you prity soon
Oct 20, 2009 | Sharp Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
