Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
All you answers are for F2 error. The question is continually F1. Still no solution posted Can you help?
  • Whirlpool Master
  • 1,902 Answers
Hello
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Posted on Nov 08, 2010
I need to press F1 when i am starting the machine
There should be an error that comes up, this error will tell you what is at issue. For example: the time is incorrect, press F1 to continue or F2 to enter setup.
Press F2 to enter set up and correct whatever the error is. Then press F10 to save and exit.
With out listing the error associated with your issue, I can only give you this general information.
Feb 10, 2012 | E-Machines Computers & Internet
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
I get F2:E0 F2:E1 and F2:E3 as well as the continuous beeping. Unplugging does not resolve the problem. I can turn on the oven, sometimes, but it goes off by itself. Sometime the controls don't work at...
Kitchen Aid Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line openfrom what this says you could have a bad touch pad,it says to press cancel,if the code comes back after a minute you have a bad touch pad.there's a tech sheet on you machine with all the codes on it,look behind the top console taped to the back.make sure you put this back,if someone comes in to work on your machine and that paper is gone it will be hard to work on it,all machines are different.
Apr 21, 2011 | KitchenAid KGST307 Gas Kitchen Range
Heloo sir i have a problem with my dell 170l when i start it it shows ''strike F1 to continue, F2 to run the setup utility'' when i click f1 it show ''f1 to retry boot,f2 for setup utility'' plz help me...
Hit F2,look in setup to see if the hard drive is recognized and check that the date and time are correct.
Then hit esc key. it will ask if you want to save changes, click yes. It should boot and probably ask you to hit F1 or F2 again., unless there is a problem with the CMOS battery, which may need to be replaced.
If you hit F1 to continue, it will boot, but your time and date will be off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Abit Av8. 2nd post fault on this m/b. post fails to complete and stops at code display 7F. screen displays . mem test OK HDD iodentified CMOS checksum error-defaults laoded F1 to continue Del to...
For that When you power up the computer press F1 or F2 or del or ALt +F2 key to enter in bios .
If still you are not able to enter in bios then open cpu cabinet if you have desktop and if you have laptop open back cover of laptop then pull cmos cell from motherboard for 10 minutes.Reattach the RAM memory .
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 03, 2010 | Computers & Internet
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
My laptop hitachi visionbook plus 5000 would not start up
Look at what the error message is and post it here. Press F1 to continue booting (try this first) Press F2 to enter Bios and make changes to the set-up
Oct 06, 2007 | Computers & Internet
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
194 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
