Question about Toshiba 72HM195 72" HDTV
Half of the screen is clear the other half is little blocks
    Sergeant:
  • 252 Answers
One of the drivers in the high voltage section is bad. It is most likely leaky electrolytic capacitors in the driver circuit that need to be replaced this will fix your problem.
Posted on Nov 08, 2010
  • i_need_h3lp Feb 10, 2011
    The same thing just happened to my tv. I dont understand how to fix it
  • 616 Answers
Willard we are talking DLP tvs here- please people DLPs use a DMD and chip, look into that portion of your tv.
Posted on Sep 28, 2011
Half the screen is black
The white dots are most likely to be failed pixels in the LCD screen. When the picture elements fail, they switch to clear and what you see as white is the backlighting.
The overheating issue in laptops is generally caused by dust and fluff blocking the cooling fins and ducts or a failed cooling fan, but it could also be caused by a hung process which runs the CPU at a high processing speed. Press control (CTRL) ALT and DEL and look at the task manager and see if you can see any processes that are running constantly near or at 100% to eliminate this being the problem.
The failing display is unlikely to be related to the overheating issue.
Mar 17, 2015 | Microsoft Surface RT
Window washer
Either jet is blocked or hose has leak! Probably jet blocked, get a pin and clear hole in jet!
Feb 08, 2014 | Volkswagen Golf Cars & Trucks
I have a Vizio SV47oxvt1a flat screen LCD TV with a video problem. Half the screen (right) half displays different colors then the (left) half. Picture is clear both sides, just divided in half.
Most likely the screen driver has failed, thay atached to the screen and not replable! ps I don't fix flat screens under 46'' any more because of price.
Aug 06, 2013 | Vizio Televison & Video
Black box blocks out lower half of television screen
Check your closed-caption settings. If you have captions on and set to "text" mode, this can happen. The TV blanks out the area on the screen where the text should go, but there's nothing to display. Turn off captions or set for regular caption mode, and that should clear up the mysterious box.
Jun 02, 2011 | Jensen Q2749J 27" TV
42 PHILIPS PLASMA HDTV 42PF7220A37 Hello, The top half and sometimes the bottom half of the screen would go black now and then, now the bottom half is distorted and theres some issues in the upper half...
Download philips latest firmware here: Click sometimes glitches can be cleared with their firmware. Also this could be a sign that your vertical buffer drivers are over-heating due to a faulty Y-sustain problem. The best way to check is to remove the back cover turn the TV on and see which buffer IC is getting red hot by touching it. Be careful as the voltage levels are dangerous, get someone who's technically proficient to do that little test for you....
http://tvtechwork.webs.com/
Oct 18, 2010 | Televison & Video
Images fading fast. Cannot read text on screen. Could hardly focus on images. Need to obtain part: Screen Focus Block
The lens is getting clogged. All u need if u have little expertise open up the TV.
and clear the lens or projection hd there with a soft clean cotton cloth
May 29, 2009 | Hitachi 51F59 51" HDTV Projection...
One half of LCD screen is not clear
I have JVC GRD73.but i need the cd installation in my computer
Sep 10, 2008 | JVC GR-D73E Mini DV Digital Camcorder
Dell Inspiron 2200 monitor issue
Could be that the monitor is going out, but it sounds more like a connector has worked loose or corroded and isn't making a good contact. Check and clean the screen connection, screen to inverter, and screen to motherboard.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Toshiba TL-S30 projector, project one half of screen colored blue, one half clear
Is it a problem...or a setting in the projector asking u to check the color settings?
Try the manual fully... Also try the monitor with some analog input (other than PC)
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Jan 07, 2008 | Sanyo PLV-WF10 Multimedia Projector
Toshiba 72HM195 72" HDTV Logo
377 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
