I have a Miller 90+ furnace running on Propane gas. We I start the furnace, everything is working perfectly except I notice that the first burner out of the 4 burners does not light. I have checked the orifice for blockage and even switched the orifice with another and it is still the burner off the first tap on the header. All four burners are in the same combusiton chamber and downstream of the main gas valve. My concern is that gas is still coming out of this orifice and eventually it may light or build up enough gas to POOF! What can be causing this burner not to light.
    President:
  • 1,515 Answers
Hi, propane gas is really hard on a furnace in causing a burner or burners to carbon up. Yes, there is gas coming from this orifice, what you need to do is grasp the burner from the front, lift the rear out of the slot it sets in as you pull forward, and take the burner out. Turn it over and clean it out. It may be full off rust and some carbon. You can do this, as it may take care of the problem. We have taken on some furnaces, if your home is heating fine on the 3 burners, and remove the orifice and just plug it off. Doesn't hurt anything at all, I believe its a 1/8 or 1/4' pipe plug. I have done this many times when the temperature rise is to high on a new unit, and the only option is to shut down one burner. No harm or adjustments needed. Try cleaning the burner first and make sure the tail end sets back in its slot. If this works, great, if not, plug it off and your set. Will save on your gas bill also.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Nov 08, 2010
When i turn the heat up sometimes it takes a long time for the gas furnace to start ..why?
Watch your furnace when you turn the thermostat up...make sure to record everything that it is doing. If you have an induced draft, forced air system, then the heat sequence of order should go like this... Initial call for heat from tstat, Inducer vent motor turns on-pulls in the pressure switch, circuit board sends power to igniter whether it is spark or hot surface, then gas valve opens. Flame sensor senses flame, burner stays on, and blower motor kicks in to heat the space. If you notice any variance from this, then something needs to be checked by an HVAC Service Tech.
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
I have a Miller furnace with central air. I am looking to change to a propane gas heater. Looking for cost of Coleman furnace, or can a miller oil furnace be changed to a gas furnace?
Yes it can do but you will be better off by gone to a gas heater. MY own furnace was chance over to propane and didn't workout to good. Less then ayear i have put in a new heater. Ken's Repair
Jan 18, 2011 | Coleman Propane Forced Air Heater...
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Miller propane furnace .red light flashes 5 times
Look on the wiring diagram for an error code chart. It will give you a starting piont.
Dec 01, 2009 | Polaroid Heating & Cooling
Gas wont ignite
unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
Feb 23, 2009 | Coleman Propane Forced Air Heater...
Blower won't stay lit
If the fan motor is blowing out the burner then is there a hole in the heat exchanger
Jul 18, 2017 | Honeywell Power Humidifier: Furnace...
Furnace rumbles when it turns on
varies from burner to burner to burner , should replace with the same as you removed , the numbers are very important on the nozzle one of the numbers is the degree of the fire pattern the nozzle produces ex. a 90 degree or 80 degree etc . this is determined by the way the fire box in the furnace is insulated . the other number is gallons per hour of oil the furnace is set up to use , ex. .70 gph or .80 gph all of these numbers are critical and should not be changed except by an expert or you could damage your furnace and could possibly be dangerous . the numbers will be on your old nozzle and should go back with same one , as to the adjustment , they also vary ,but i can give you one that will usually work for most furnaces , that is one eighth inch space between electrode tips , five eights in front of nozzle port opening , and one half inch above center of nozzle center , where the hole is . bleed all air out of system after installing nozzle , let me know if no fix have more ideas
Nov 21, 2008 | SySTOR Systems (400S52) Burner
Adjusting goodman propane burners
Yellow flame can also mean inadequate gas pressure. Do you have a manometer? If not, call your gas company for a check.
Oct 09, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
137 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
